pwmin Posted 20 hours ago Report Posted 20 hours ago I moved the coils on my turbo Monte and I was getting a CEL (1530, I think), but it would run and drive fine. Didn't get it figured out and then it decided it didn't want to stay running. I found the power wire to the coil had a break in the connector I used to extend the wire, so I fixed that and now it cranks, but won't start (no spark). The wires test good and the 7x crank sensor as well. We had put a new ICM on, so I went back to the old one and same thing. From what I've gathered, the only things that it could be is power to the coil, the wires to the crank sensor, the crank sensor or the module/coils. If you unplug the 5-wire connector it should still get base timing and start. Any ideas? 94 olds vert 1 Quote
