97cutty Posted July 16, 2025 Report Posted July 16, 2025 (edited) anyone on here that owns a cutlass with aftermarket wheels could you post a picture under this post of your ride, with wheel fitment specs. thanks to all i’m trying to figure out what type of wheels i want to put on and i was also wondering if a set of 18x8.5 +30 wheels would be too wide for the front or if the offset helps tuck enough Edited July 16, 2025 by 97cutty Go4DaMo 1 Quote
GnatGoSplat Posted July 18, 2025 Report Posted July 18, 2025 18x8 +42 with 5mm spacer = +37. Needed spacers to clear the front calipers, and I didn't want the rear to look more tucked than the front, so I put spacers on the rear just to match. Your tires would stick out 7mm more than mine if you go for 245-wide. 97cutty 1 Quote
97cutty Posted July 26, 2025 Author Report Posted July 26, 2025 (edited) i’d go a little smaller of tire because the overall plan is to put airbags on it when the shop gets a spot open, the goal for me is to have the wheels flush with the body the tires slightly in more than the wheels to have a mean ass fitment when the air bags to air out but Edited July 26, 2025 by 97cutty GnatGoSplat 1 Quote
GnatGoSplat Posted July 26, 2025 Report Posted July 26, 2025 As long as you're not looking for it to tuck, that should be no problem. Quote
97cutty Posted August 16, 2025 Author Report Posted August 16, 2025 On 7/25/2025 at 11:09 PM, GnatGoSplat said: As long as you're not looking for it to tuck, that should be no problem. well i can always stretch the tires a little to tuck it more the wheels can’t be wider than the body or it’s going to look terrible Quote
