91 Grand Prix window motors
Hello and yes, the pwr window motor and regulator are one unit.  They are riveted in from factory.  You'll need to drill them out and I slid the whole assembly out thru the door cavity.  I didn't have to remove the door glass.  I moved the regulator or lift arm for the glass thru one end of the glass channel to remove it and left the glass in the door.
Edited by jiggity76
  • Like 1
30 minutes ago, pwmin said:
Yay, looking forward to doing the one in my Monte.  I've had the motor for weeks now :burger:
For me...and for a 1991 W body car, it wasn't that bad really.  I was expecting a lot of work but surprisingly easy.
I've done this on an '88, you don't have to remove the glass.  Just put something over the window frame and tape the glass up.  The lift arm has a wheel that rolls horizontally in a channel.  Once you've got the regulator loose, you can move the lift arm far enough to the side that the wheel will come out of the channel and the regulator will be completely loose in the door.
Monte looks a little different.
https://charm.li/Chevrolet/1995/Monte Carlo V6-204 3.4L DOHC VIN X SFI/Repair and Diagnosis/Windows and Glass/Windows/Window Regulator/Service and Repair/Window Regulator/Regulator/
