Cooling fan questions
TGP 1989
When operating without the air conditioner on, everything is fine. But when we turn on the air conditioner, even on a cold engine, both the main and additional fans turn on immediately. The question is - is this a normal operating mode? After all, the pressure sensor should be responsible for turning on the fans, but the control unit ignores any state of the sensor.
Indeed it is........
both the primary & secondary fans will engage.
The low pressure sensor engages the entire system when the system is above approx 40lbs, the compressor does NOT cycle, once engaged it runs 100% of the time the a/c is turned on (depending on the volume of system charge).
I just rebuilt the A/C system in the International and yes, both fans run when the A/C is on.  The fans and the compressor is doing exactly how 55trucker is describing.
I should also add that the coolant fans engagement is speed dependent, when the a/c is on the pcm will disengage the fans as the vehicle speed increases to the point when they no longer need to be.
When I first started charging the A/C system, the driver side fan kicked on.  It might have kicked on when I actually pressed the climate control panel.  As I started filling the system...I think with the start of the 2nd bottle of freon, the compressor kicked on as well as the passenger side fan.  Yes, when I'm on the HWY or Interstate, I'm assuming both fans have shut down long ago by that point.  I can then hear them, (and feel a little bit), when I'm back in city driving mode.
But it turns out that if the car is stuck in a traffic jam at idle speed and the brakes are pressed, and plus two fan, the voltage drops
alternator - new  105a
Edited by Megavolt-380
Was this the mode from the factory?
then what is the purpose of the pressure switch near the dryer?
Yep, that's what happens at idle, the idle speed needs to be at least 800rpm to combat the load on the charging system. In those situations put the trans in neutral, raise the engine rpm to get the charge rate back up. Something one can do is to pull out the secondary fan relay to prevent the secondary fan engaging. The secondary fan only engages when the a/c is on, it very seldom engages for engine temp cooling purposes as it doesn't engage until the engine temp is near 220F degrees. The side effect of this is the condenser will not dissipate as much hot air as both fans running.
The pressure switch is a necessary device to prevent the compressor engaging when there is not enough refrigerant in the system.
How much is it dropping? These cars had a rather undersized charging system from factory. Especially a TGP with the terrible braking system.
low and high pressure switches mount on compressor, fan pressure switch near the dryer
about 12v and below
The v5 has only one single high pressure blow off valve mounted into the back end of the housing.
The system low pressure switch is as you noted next to the receiver/dryer.
39 minutes ago, Megavolt-380 said:
about 12v and below
Normal system voltage output should be approx 14.2v, one can check that with a simple voltmeter. that voltage level is seen on the voltage gauge in the cluster, if one loads up the system at engine idle note with the meter what the system is dropping off to.
I've been where you are, to get around this 2 years ago I replaced the original output 105 amp alternator with a 140 amp unit. Idle voltage issue was significantly reduced.
No!
on 1989 model year - low and high pressure switches mount on compressor, fan pressure switch near the dryer
That is correct, my 1990 has the same setup.
12 hours ago, Megavolt-380 said:
No!
Negative.........
all of the early design housing of the V5 will have a pair of *mechanical* internal switches inserted into the back housing, they are held in place by a pair of inside C-clips, they work in conjunction with the swash plate to regulate the pressure differentials between the discharge side pressure & the suction side pressure. They have nothing to do with *electrical* switches and are completely self contained.
Later models of the V5 (circa 1999) have a completely redesign back housing which has done away with those 2 *mechanical switches*, improvements in the compressor internal design eliminated them altogether.
my 1990 for sure has a pair of electric switches on the back of the compressor
 ^ Jeez Chris, you've got some arrangement I've not come across, even our previous '90 GP fitted with the V5 had no electrical fittings on the tail end of the compressor housing.
Obviously the engine wiring harness goes to the switches?
Edited by 55trucker
asleep at the wheel
Yes, there are two sensors connected to the back of the compressor, low and high pressure
the question is in principle about polling the pressure sensor on the tube near the dryer, according to the diagram it is indicated as a two-stage switch, on the control unit the contacts to it are marked as  Hi  and Lo Coolant Fan Request
but the control unit does not respond to the sensor signals
in my opinion, two fans should not turn on at once
On my GP 1991  LQ1   the scheme is implemented on one pressure sensor, which is located near the dryer and shows the exact pressure in the system. In this case, the fans are switched on in turn depending on the pressure. And in this version, there are no sensors on the compressor.
As both you & Chris state the compressor has electrical switches on the back of the housing then the engine wiring harness must have a sub harness that goes to those switches.
So the PCM will control both switches & will command them in the manner the PCM program was written.
all wiring is connected. no one talks about free sensors and connectors. the question is in the logic of turning on the cooling fans.
Why worry about it?
the only way that one can change the controlling of the fans is to reprogram the PCM.
