gr_elvis Posted June 20, 2025 Report Posted June 20, 2025 Why won't my top go all the way down on one side? Quote
Human Posted June 25, 2025 Report Posted June 25, 2025 (edited) You could have a broken piston on the side that isn't working. I encountered this on my '95 vert last fall. I took the car out for some exercise on a warm afternoon in October, and when I put the top down, there was a loud 'POP', which I found out later was the piston actually snapping off. When I later tried to put it back up, only one side came up. I finally got the top completely up by having a friend operate the switch, while I assisted the broken side to keep it even with the side that was working. I took it to a trim shop a few weeks later, and the guy replaced both pistons, and stapled and screwed the top back into place where it had come loose between the rear seat and trunk lid, and it's been working fine ever since, actually better than it had before. He said he always replaced those pistons in pairs because when one breaks, the other is usually not far behind, and doing them both at once saves significantly on labor. Edited June 25, 2025 by Human Quote
gr_elvis Posted June 26, 2025 Author Report Posted June 26, 2025 That's not the problem, it just doesn't go all the way down so that you can put the boot on it. Both sides go up and down. Quote
