SuperBuick Posted May 28, 2025 Report Posted May 28, 2025 So I bought this pulley from a known community member on facebook (not a scammer), and I installed it, and when I started the engine it instantly shredded the belt. I assumed I did something wrong but on closer inspection the pulley is way too "shallow". Did I get a pulley for the wrong engine? I compared the stock pulley on my 3.4 to my spare engines and they are all deep (like the black one in the picture). The directions do not mention any spacer or anything. Quote
SuperBuick Posted May 28, 2025 Author Report Posted May 28, 2025 And grabbing some old photos from fast fwd performance on the internet archive, its hard to tell... Pic 3 is for the pushrod motors... Quote
Schurkey Posted May 29, 2025 Report Posted May 29, 2025 Why sabotage the A/C, water pump, and alternator output? Quote
White93z34 Posted May 30, 2025 Report Posted May 30, 2025 Does the 94-97 engine use a different harmonic balancer to account for the additional crank pulley? That could explain it. I assume you're installing on a 91-93 engine? Also even all these years later I never knew ASP was a company let alone made parts for these cars. pwmin 1 Quote
SuperBuick Posted May 31, 2025 Author Report Posted May 31, 2025 Not sure on the different balancer - thats a great point. I only have 91-93 engines to compare to. I'll try to get a look at a later engine to see if there is any difference. Yeah ASP is a pretty common pulley company, or at least they were. I definitely feel like I've known of them for a long time Quote
Bake82 Posted June 3, 2025 Report Posted June 3, 2025 A 94+ 3.4 Harmonic balancer as per rock auto, which looks similar to your aftermarket pulley. Rockauto does not list a 91-93 harmonic balancer. Most likely explains the issue you're having SuperBuick 1 Quote
SuperBuick Posted June 19, 2025 Author Report Posted June 19, 2025 So it seems like unless i have the 94 motor, this pulley wont work on the 91-93? Quote
