Jakey Posted 5 hours ago Report Posted 5 hours ago Does anyone know what is involved in removing the radio on this model? The trim is brittle and I don’t want to break anything that can’t be replaced. I removed the trim screws from under the top of the dash but I’m afraid to slide the trim out that goes around the radio and gauges. Quote
jiggity76 Posted 1 hour ago Report Posted 1 hour ago (edited) That's your only option. Once those screws are out, you have to pull that bezel towards you as it's held on with tension clips. The clips are metal and won't break. I've never had a problem with the bezel breaking either. It will sound like it's going to break...creaking and moaning, but it will come. Also, I just disconnect the connector for the headlamps switch, I don't remove it from the bezel. With the bezel out, you'll see two 7 mm screws I think they are that holds the radio to the main dash. They will be at the bottom of the radio. The radio will slide out and give you some room to disconnect the connectors from the back of it. Disregard the dash pad being off. It's not necessary to remove the pad when just removing the radio. Edited 1 hour ago by jiggity76 Quote
