92 (88-94?) sunroof relay
So I’ve owned my GTP for 15 years and for at least 10 of those years the sunroof has always been kinda iffy, but only on one side of the button press. I confirmed years ago that it wasn’t a button issue (and have just the other day reconfirmed), so the next step was the relay. It thought I did some decent research and ordered GM part number 21038764, which was labeled for a Saturn but also came up with many other GM makes because GM. When I went to install it, I realized the body is identical, and the insides seem to be almost identical (minus a few resistors and what appears to be a voltage regulator or something, I don’t know), but the wiring is different. I’m wondering if anyone more knowledgeable than me can confirm of the electronics are in fact the same and if I can repin the plugs and slap it in, or if there’s something different and I can’t. Alternately, if anyone knows the correct part number that would also be helpful
picturws attached
old has the resistors. When comparing plugs, left is original, right is new one
Edited by Psych0matt
  • Like 1
2 hours ago, Schurkey said:
  • Thanks 1
I've been hitting my head against the wall trying to figure this out. After several failed attempts to locate anything for the 1992 GTP, other than what you've already sourced.  I had an idea. Don't know if it's possible but it might me.
Would it be possible to replace the relays in the original connector? Either using the ones in the new unit or ordering AROMAT relays. I'm sure that might be the only issue. I would assume you've already inspected the solder joints for any cracking.
Now think I'm thinking about it, the resistors in the old unit could be the issue.
Rewiring and using the old connectors on the new unit might be the way to go.
Edited by 94 olds vert
I have zero issues doing this physically, I just have no idea if the internals of this newer one are the same, and I’m not sure I want to bastardize both and end up with nothing haha
I was gonna  plug the old one in and close it so I could at least drive it but it makes getting to this piece 1000x more difficult lol
edit: I looked over the traces and didn’t visibly see anything that stood out, but given it works sometimes (without any perceivable reason) it may be something I can’t see. I thought about ordering replacement relays but I’m not sure that would work. I’m very tempted to cut wires in the middle and put the old ends on the new wires in the appropriate order and see what happens. I just wish I knew
  • Like 1
  • Thanks 1
Matt...
In one of those uploaded pics you supplied....there are 4 zener diodes inside the housing (those 4 black & silver round items look like them).
If any one of them has failed (shorted) that will upset the operation of the control mechanism.
One can see the diode array in the attached pic
Edited by 55trucker
  • Like 2
  • Like 1
  • Like 2
Those aren't resistors but rectifier diodes.  The 3rd small box is a small low power relay.  Looks like the purpose is to cut power to the main relay coils when the sunroof hits end of travel so you don't accidentally burn up the motor.
I'm surprised it needed a protection circuit like that as I don't think power window motors are protected like that.
Only part # I could find for sunroof relay is 20652833.  Can't find any photos of it, so I don't know if that was the right one.
  • Like 1
Oh wait, was that so it would turn off when it fully shut, so it wouldn't continue into the vent position, or when in vent and you go to shut it, it doesn't continue to fully open?  If that's what it was for, I can see why they did it now.
Not 100% without seeing bottom of the boards, but it's probably possible to desolder the individual relays off the one board and replace them on the other.  They look about the same size and probably same pinouts.  Might be challenging if you don't have any desoldering tools.
Yep, that makes sense and brings back memories that my TGP also wouldn't stop, but in my case, it was the little switch was packed full of dirt and I had to clean it out, then it would stop.
Now I see why they did it that way.  Interesting that it's not fully integrated into the Saturn unit, I'd guess they use an external 3rd relay for that function.
either that or it’s like my 06, it vents and then slides. But I guess it would still have to have a stop function somewhere…
I don’t know, I’m just happy it’s working
