Psych0matt Posted May 11, 2025 Report Posted May 11, 2025 So I’ve owned my GTP for 15 years and for at least 10 of those years the sunroof has always been kinda iffy, but only on one side of the button press. I confirmed years ago that it wasn’t a button issue (and have just the other day reconfirmed), so the next step was the relay. It thought I did some decent research and ordered GM part number 21038764, which was labeled for a Saturn but also came up with many other GM makes because GM. When I went to install it, I realized the body is identical, and the insides seem to be almost identical (minus a few resistors and what appears to be a voltage regulator or something, I don’t know), but the wiring is different. I’m wondering if anyone more knowledgeable than me can confirm of the electronics are in fact the same and if I can repin the plugs and slap it in, or if there’s something different and I can’t. Alternately, if anyone knows the correct part number that would also be helpful picturws attached old has the resistors. When comparing plugs, left is original, right is new one Quote
Psych0matt Posted May 11, 2025 Author Report Posted May 11, 2025 (edited) Pics since they wouldn’t upload here https://imgur.com/a/0TaF7Mj Link from Nate for diagram https://charm.li/Pontiac/1992/Grand Prix V6-204 3.4L DOHC/Repair and Diagnosis/Diagrams/Electrical Diagrams/Sunroof %2F Moonroof/ Edited May 11, 2025 by Psych0matt 94 olds vert 1 Quote
Psych0matt Posted May 11, 2025 Author Report Posted May 11, 2025 (edited) It looks like the end plug is wired the same (looks like power?) but has a different connector, and the second to last one as well and has the same connector, so the main difference is on the original the first plug (that goes to the stop switch) has three wires, but on the new it only has 2, with the third wire going to the second plug instead; both of those having different connectors as well. I’d bet this would function the same if repinned/spliced to the correct connectors. Some are different sizes so I don’t think I can just reuse the end connectors without splicing Edited May 11, 2025 by Psych0matt 94 olds vert 1 Quote
Psych0matt Posted May 12, 2025 Author Report Posted May 12, 2025 Here’s the diagram for the Saturn part number I ordered. Posting here so I can compare it later (currently at work in the John haha) https://charm.li/Saturn/1995/Sedan L4-1.9L SOHC VIN 8/Repair and Diagnosis/Diagrams/Electrical Diagrams/Sunroof %2F Moonroof/ Quote
Schurkey Posted May 13, 2025 Report Posted May 13, 2025 HOW does the relay know which side of the button you're using? Quote
55trucker Posted May 14, 2025 Report Posted May 14, 2025 2 hours ago, Schurkey said: HOW does the relay know which side of the button you're using? The sunroof switch is a rocker switch, depending on which side of the switch one presses (front side or rear side) the switch closes the circuit to either the forward relay or the back relay. The direction of sunroof movement remains in play until the end of stroke as long as one has the switch pressed. If the sunroof glass has been opened & one presses the front side of the rocker switch the glass moves forward to the closed position, one releases the switch at the point the glass is closed to keep the glass closed, if one continues to hold down the front side of the switch the glass will open up to the vent position. The same control function takes place when retracting the glass to full open, when the glass goes to full open the glass stops moving, the load comes up on the motor circuit, no voltage is flowing, so both relays go open, this same action applies when the vent goes to fully open. 94 olds vert 1 Quote
94 olds vert Posted May 14, 2025 Report Posted May 14, 2025 (edited) I've been hitting my head against the wall trying to figure this out. After several failed attempts to locate anything for the 1992 GTP, other than what you've already sourced. I had an idea. Don't know if it's possible but it might me. Would it be possible to replace the relays in the original connector? Either using the ones in the new unit or ordering AROMAT relays. I'm sure that might be the only issue. I would assume you've already inspected the solder joints for any cracking. Now think I'm thinking about it, the resistors in the old unit could be the issue. Rewiring and using the old connectors on the new unit might be the way to go. Edited May 14, 2025 by 94 olds vert Quote
Psych0matt Posted May 14, 2025 Author Report Posted May 14, 2025 (edited) 11 hours ago, 94 olds vert said: Rewiring and using the old connectors on the new unit might be the way to go. I have zero issues doing this physically, I just have no idea if the internals of this newer one are the same, and I’m not sure I want to bastardize both and end up with nothing haha I was gonna plug the old one in and close it so I could at least drive it but it makes getting to this piece 1000x more difficult lol edit: I looked over the traces and didn’t visibly see anything that stood out, but given it works sometimes (without any perceivable reason) it may be something I can’t see. I thought about ordering replacement relays but I’m not sure that would work. I’m very tempted to cut wires in the middle and put the old ends on the new wires in the appropriate order and see what happens. I just wish I knew Edited May 14, 2025 by Psych0matt 94 olds vert 1 Quote
Psych0matt Posted May 15, 2025 Author Report Posted May 15, 2025 Any idea what the resistors are for Nate? That’s really the only thing that looks different. I’m gonna look up the relays but I can only assume (and I think the wiring diagram confirms, for check again) that both units just have two identical NO relays. So assuming all the wiring to them is the same, requiring the ends should in theory work. I mean it’s just power, one relay for each side, and essentially an end switch to stop the motor once it hits fully open/closed 94 olds vert 1 Quote
55trucker Posted May 15, 2025 Report Posted May 15, 2025 (edited) 1 hour ago, Psych0matt said: Any idea what the resistors are for Nate? That’s really the only thing that looks different. I’m gonna look up the relays but I can only assume (and I think the wiring diagram confirms, for check again) that both units just have two identical NO relays. So assuming all the wiring to them is the same, requiring the ends should in theory work. I mean it’s just power, one relay for each side, and essentially an end switch to stop the motor once it hits fully open/closed Matt... In one of those uploaded pics you supplied....there are 4 zener diodes inside the housing (those 4 black & silver round items look like them). If any one of them has failed (shorted) that will upset the operation of the control mechanism. One can see the diode array in the attached pic Edited May 15, 2025 by 55trucker Psych0matt and 94 olds vert 2 Quote
Psych0matt Posted May 15, 2025 Author Report Posted May 15, 2025 I need to take a good look and compare these two sometime (just haven’t had a chance). Even if not a direct replacement, should easily be able to make something work. I did look into just buying a few replacement relays for my original unit, but that doesn’t help if it’s a broken trace. That and I’m rubbish at soldering haha. 94 olds vert 1 Quote
Psych0matt Posted May 16, 2025 Author Report Posted May 16, 2025 I said screw it cut/spliced the old ends on the new relay module with the single wire changeover to match, and aside from not having tested the end switch (routing is a pain) it works flawlessly. I’m gonna get some proper crimp connections or solder joints and clean it up before reinstalling. rich_e777 1 Quote
Psych0matt Posted May 16, 2025 Author Report Posted May 16, 2025 (edited) So, the stop switch doesn’t function, but I can way more live with that, everything else functions perfectly. Edited May 16, 2025 by Psych0matt rich_e777 and 94 olds vert 2 Quote
GnatGoSplat Posted May 18, 2025 Report Posted May 18, 2025 Those aren't resistors but rectifier diodes. The 3rd small box is a small low power relay. Looks like the purpose is to cut power to the main relay coils when the sunroof hits end of travel so you don't accidentally burn up the motor. I'm surprised it needed a protection circuit like that as I don't think power window motors are protected like that. Only part # I could find for sunroof relay is 20652833. Can't find any photos of it, so I don't know if that was the right one. 94 olds vert 1 Quote
Psych0matt Posted May 19, 2025 Author Report Posted May 19, 2025 8 hours ago, GnatGoSplat said: Those aren't resistors but rectifier diodes. The 3rd small box is a small low power relay. Looks like the purpose is to cut power to the main relay coils when the sunroof hits end of travel so you don't accidentally burn up the motor. I'm surprised it needed a protection circuit like that as I don't think power window motors are protected like that. Only part # I could find for sunroof relay is 20652833. Can't find any photos of it, so I don't know if that was the right one. That's what I came to figure once I wired this one in and discovered that. I could take the time to make something at some point but I don't see this being much of an issue, way less so than not being able to close it Quote
GnatGoSplat Posted May 19, 2025 Report Posted May 19, 2025 48 minutes ago, Psych0matt said: That's what I came to figure once I wired this one in and discovered that. I could take the time to make something at some point but I don't see this being much of an issue, way less so than not being able to close it Oh wait, was that so it would turn off when it fully shut, so it wouldn't continue into the vent position, or when in vent and you go to shut it, it doesn't continue to fully open? If that's what it was for, I can see why they did it now. Not 100% without seeing bottom of the boards, but it's probably possible to desolder the individual relays off the one board and replace them on the other. They look about the same size and probably same pinouts. Might be challenging if you don't have any desoldering tools. Quote
Psych0matt Posted May 19, 2025 Author Report Posted May 19, 2025 Yeah, the way the roof is setup on this (and I assume other W's and other GMs of the era) is that the closed position is in the middle. From closed button "a" we'll call it opens it to vent, and then "b" will close it from vent. From closed button "b" will slide it back into the roof, and button "a" slides it back to closed. There's a little switch that the glass frame hits when in the closed position that stops the motor, so I lost that function, but from the looks of it the relay setup otherwise is identical. Quote
GnatGoSplat Posted May 19, 2025 Report Posted May 19, 2025 Yep, that makes sense and brings back memories that my TGP also wouldn't stop, but in my case, it was the little switch was packed full of dirt and I had to clean it out, then it would stop. Now I see why they did it that way. Interesting that it's not fully integrated into the Saturn unit, I'd guess they use an external 3rd relay for that function. Quote
Psych0matt Posted May 19, 2025 Author Report Posted May 19, 2025 either that or it’s like my 06, it vents and then slides. But I guess it would still have to have a stop function somewhere… I don’t know, I’m just happy it’s working Quote
