Last American Indian Posted February 4, 2025 Report Posted February 4, 2025 Hearing loss is obviously not great! And your condition of Meniere’s is unfortunate indeed. I’m sure you’ve looked at things to help. Are you aware the alpha lipoid acid supplements will help help to protect the hearing in the case of Meniere’s? I wish you the best with this. GnatGoSplat 1 Quote
bluecalais79 Posted February 26, 2025 Report Posted February 26, 2025 Factory all the way for me. But I did upgrade to CD from cassette, a factory correct unit, in my 94 CS RPE1992GPSE, GnatGoSplat and rcLord510 2 1 Quote
GnatGoSplat Posted February 18 Author Report Posted February 18 Finally committed (a year later) to go back to stock. Debating whether I should remove the 4ga amp wire while I'm in there. It runs through the factory grommet and inside the door sill trim with the rest of the factory wiring. Underhood, there's just a red wire neatly wire-tied to the cruise control cable and disappearing into the firewall. The end underhood is a ring terminal tucked away, so you can't see where the end actually terminates. There is no longer a fuse or length of wire going to the battery terminal or positive jump start terminal. Personally, my amps & subs days are long over. I'm not sure if anyone who would buy a vintage W-body would still be into amps & subs. I'm already pulling trim to remove the 20yr old DVD navigation I've got in it, so it's not a ton of extra hassle. 2 of 2 AIs are telling me this: Quote Right now, that loose 4-ga amp wire sends a subtle signal: this car has been messed with electrically. Bottom line, both say to pull it. Agree? Disagree? I know if someone did want amps & subs, leaving it would save them a whole lot of trouble. Quote
bluecalais79 Posted February 19 Report Posted February 19 (edited) Agree. As I always say, your car, your call. Do it for what you want rather than what the next owner may (or may not) want. I myself am after the total factory look, but if I can hide something that will otherwise give it the factory look, that's good news. I've replaced my Retrosound rear speakers with another aftermarket brand set that fits into the hole and under the grille sufficiently. They get hit by the sun with that huge rear window so I avoided a paper coned speaker with something more durable. I'm loathing replacing the door panel speakers, but as soon as II find that set of correct NOS ones I've got in storage somewhere, I've got a job to do............ Edited February 19 by bluecalais79 GnatGoSplat 1 Quote
Black92GS Posted February 19 Report Posted February 19 If it were me I'd pull it... but I also wouldn't worry too much about seeing it neatly tied up and disconnected at both ends if I were a buyer. It was the style at the time to run aftermarket stereos in nearly everything, so I consider it to be remanent of a former, period correct modification. GnatGoSplat 1 Quote
GnatGoSplat Posted February 19 Author Report Posted February 19 I was thinking along the lines of anyone being interested in this car is likely to be a millenial or X'er that isn't going to be as into subs & amps as someone in their 20s. As far as doing it for me, I'm in "do what makes it most appealing to sell" mode. if I were intending to keep the car, I'd leave all my mods intact as I really liked them. However, I'm out of space and had to pass up a semi-unicorn car I really wanted that was priced very aggressively because of it. Quote
Black92GS Posted February 19 Report Posted February 19 1 hour ago, GnatGoSplat said: I was thinking along the lines of anyone being interested in this car is likely to be a millenial or X'er that isn't going to be as into subs & amps as someone in their 20s. That's how I'm looking at it. I wouldn't have not bought the Regal, or insisted on paying any less for it if there was a disconnected and neatly stored amp wire running back to the trunk, everything else being equal. My thought is that the target buyer for that car is the type of person to be a member here, and is likely to be relatively well versed in them to where something like that wouldn't make a difference in either case. It's not a super low mileage museum piece where I feel something like that would make a difference. If anything, that car being "The Car" of these forums makes it more desirable, but that's just me. GnatGoSplat 1 Quote
GnatGoSplat Posted February 19 Author Report Posted February 19 Right. It's no museum piece and has a lot of legit serious issues that will greatly degrade its value that this is nothing in comparison. Just trying to decide if it's worth pulling when I already have the rest of the interior torn apart to remove all my other less obvious electrical mods. Quote
GnatGoSplat Posted March 17 Author Report Posted March 17 Well, that's not fun. Got all the aftermarket audio equipment pulled. Plugged in the factory radio and... sounds distorted on the left channel, right channel completely out. Pop sounds when I push the buttons. It worked fine when pulled 32-years ago, so I'm guessing something that ages has gone bad. Probably electrolytic capacitors. I've read there are some green ones that like to go bad and leak. I just learned today the amp/radio module is the same as used in GMT400 pickups. I guess that explains why these radios are modular and can be taken apart into smaller modules. Vehicles with the split radios used the same modules with cables connecting them. pwmin and RPE1992GPSE 1 1 Quote
Black92GS Posted May 26 Report Posted May 26 On 3/17/2026 at 5:44 PM, GnatGoSplat said: I just learned today the amp/radio module is the same as used in GMT400 pickups. I guess that explains why these radios are modular and can be taken apart into smaller modules. Vehicles with the split radios used the same modules with cables connecting them. Apparently, they are a lot more common than we may realize. Any 2 piece HU like yours used those radio modules. The 88-94 Regals, the early GPs, Sunbirds, 88-94 GMT 400s etc…There were also a number of variations of them, based on whether there was just bass and treble controls or the 5 band eq, as well as whether they were equipped with AM stereo capabilities or not. I’d venture an educated guess that every OBD1 GM vehicle with steering wheel controls is just about guaranteed to use one. On the GMT400 front, I have heard that the modules intended for the 5 band EQ models also have a higher power amplifier in them. I tend to believe that, based on my experience with my Regals Pretty sure those also have some sort of databus that is accessible via a Tech 1. There are troubleshooting steps in my Regal FSM that allude to using bi-directional controls on a Tech 1 to monitor and control some of the radio functions for troubleshooting purposes. GnatGoSplat 1 Quote
Raffaelli Posted May 26 Report Posted May 26 The factory radio is cutting in and out on some of the speaker channels in mine as well. I’m sure it’s some caps going bad. Quote
GnatGoSplat Posted May 26 Author Report Posted May 26 59 minutes ago, Black92GS said: Apparently, they are a lot more common than we may realize. Any 2 piece HU like yours used those radio modules. The 88-94 Regals, the early GPs, Sunbirds, 88-94 GMT 400s etc…There were also a number of variations of them, based on whether there was just bass and treble controls or the 5 band eq, as well as whether they were equipped with AM stereo capabilities or not. I’d venture an educated guess that every OBD1 GM vehicle with steering wheel controls is just about guaranteed to use one. On the GMT400 front, I have heard that the modules intended for the 5 band EQ models also have a higher power amplifier in them. I tend to believe that, based on my experience with my Regals Pretty sure those also have some sort of databus that is accessible via a Tech 1. There are troubleshooting steps in my Regal FSM that allude to using bi-directional controls on a Tech 1 to monitor and control some of the radio functions for troubleshooting purposes. Oh, I didn't know about the J-bodies having the same radio, but it makes sense. I think some 3rd-gen F-bodies used the same radio as the Grand Prix. I'd read the same thing about the amps on the GMT400 forum while searching for info on these, as I'd wondered if I could just replace my CDM module rather than repairing it, but ended up deciding that'd be pointless as probably all of them need those capacitors by now. Anyway, I can confirm the amplifiers are 100% the same between the non-EQ and 5-band EQ models. There is no difference whatsoever between the amplifier stages. They're both using a pair of Delco DM165 2-channel amplifier ICs. In fact, I used my 5-EQ CDM (from GP radio) as a DM165 donor for my non-EQ Cutlass radio because one of its DM165s was blown. There's only one difference between the non-EQ and 5-EQ models and that's the presence of the EQ IC. In the non-EQ model, there are shorting jumpers (yellow arrows in the image) to connect the EQ input solder pads to EQ output pads. That said, there is a newer CDM with different amplifier ICs. You can tell them apart because the amplifier heatsink has vertical fins instead of horizontal. It's very likely that one does have more powerful amps. In this pic, top is old (like I have) and bottom is the newer one. The GMT400 thread did mention the old and new style are completely interchangeable. They communicate via E&C Databus, which has been somewhat hacked. https://stuartschmitt.com/e_and_c_bus/ I think Tech 1 and Tech 2 have the ability to read it with the right cartridge and cable. 17 minutes ago, Raffaelli said: The factory radio is cutting in and out on some of the speaker channels in mine as well. I’m sure it’s some caps going bad. If it uses a CDM similar like the top one in the previous pic, then I'd bet on it. Black92GS, RPE1992GPSE and Raffaelli 2 1 Quote
RPE1992GPSE Posted June 1 Report Posted June 1 This, kids, is why this website is the fucking best when it comes to W-Bodies. 94 olds vert and GnatGoSplat 2 Quote
