architect Posted September 10, 2024 Report Posted September 10, 2024 (edited) I posted this on Reddit and was told to come over here Someone is giving me their 1995 Regal GS that's been sitting for a few years after her husband passed. She's older so hard to know if her memory of timing is right. The battery is dead and the tires look deflated. It's only got ~100,000 miles on it. I'm planning on getting it towed straight to the mechanic, but also wondering if I can just replace the battery, put some air in the tire, and drive it home first or would that just cause more problems? I don't have indoor marking so the car will have to stay outside and endure the winter Edited May 21, 2025 by architect pwmin, primergray, rich_e777 and 1 other 4 Quote
White93z34 Posted September 10, 2024 Report Posted September 10, 2024 Welcome to the site! Depending on how long its been sitting you could air up the tires, put a new battery in it and see what happens when you hit the key. I'd check to make sure the fluids are at least present before you do that though. Once its up and running fresh fluids all around and a through inspection would be a good idea. You could check the date codes on the tires to try and get an idea of when it was last on the road. Guessing you're in Ontario by the tag and Drive Clean sticker. So If you're going to winter drive it get it oil spray undercoated every year to keep it from dissolving. If you're not familiar that really helps a car last in the salt and rust belt. Oh one other thing, don't have too much faith in the doors in the winter. YMMMV but I found myself just not locking the doors often as I valued getting back in the dang car. If its been sitting for an extended time I'd probably get the fuel drained if the tank has to come down a new fuel pump would probably be a smart idea as well. primergray and architect 2 Quote
White93z34 Posted September 10, 2024 Report Posted September 10, 2024 Also it will forever be baffling to me as to why some of those Buicks had the support bars omitted like that one has. 94 olds vert 1 Quote
Black92GS Posted September 11, 2024 Report Posted September 11, 2024 The lack of cross braces is a series 1 3800 thing. I have yet to see a 1st gen Regal with a series 1 3800 have them. Regals with the 3.1 and 3100s had them, as did the 96s with the series 2 3800. No clue as to why it’s that way though. primergray 1 Quote
Black92GS Posted September 11, 2024 Report Posted September 11, 2024 Also, just a bit of a warning. If a trans fluid/filter change is in the books, it might be a good idea to insist that they use dexron /mercon fluid, instead of DexVI or something like Valvoline MaxLife. You can't get licensed Dexron III these days, so the Dex/Merc fluids that state they are for older GM and Ford vehicles are going to be the closest you can get. I have a 1992 Regal that is fairly low milage (currently under 72k KMs) that still had its original trans fluid in it. It was due for a change, but otherwise everything was functioning as it should. I did a pan drop, changed the filter, and re-filled with Valvoline MaxLife. Got the levels set, and everything seemed great. In short order though, I was dealing with a downshift issue into 1st. Essentially, when the vehicle went into lockup before the trans was fully warmed up, slowing down to the point where 1st would engage resulted in the trans acing as if it were in neutral. Even the increased line pressure in manual 1st. wasn't enough to engage it. You could shift to Neutral and back into Drive though, and it would act exactly as expected, so I simply worked around it and shifted into Neutral while slowing down, then back into Drive just before coming to a stop. The more I dug into the issue, the more I realized that the MaxLife was likely the cause, as older transmissions don't necessarily play nice with the much lower viscosity of MaxLife. I just recently pumped out 4.5 quarts of trans fluid and replaced it with Dex/Merc, and on the first test drive the issue was nearly eliminated. My plan now is to drive it a little bit more, then pump it out and refill again to get as much out as possible. I will be sticking with Dex/Merc from now on for this one. architect and primergray 1 1 Quote
55trucker Posted September 11, 2024 Report Posted September 11, 2024 Personally I'd rather look for as many needed bottles of AC DELCO ATF Type III (H) which one can still purchase today, it IS GM's designated fluid for all older transmissions that used Dexron II or Dexron III (H). primergray and architect 2 Quote
Pontiac6KSTEAWD Posted September 11, 2024 Report Posted September 11, 2024 (edited) If you dont want it... Let me know! Depending on where you live anyways... That would make a perfect car for a family I am trying to help out. Edit: Nevermind... Ontario would be entirely to far, and the import fees would kill me! That undercarriage is CLEAN for a Canadian car! Still a sweet looking GS Edited September 11, 2024 by Pontiac6KSTEAWD Quote
55trucker Posted September 12, 2024 Report Posted September 12, 2024 On 9/10/2024 at 8:45 AM, architect said: I posted this on Reddit and was told to come over here Someone is giving me their 1995 Regal GS that's been sitting for a few years after her husband passed. She's older so hard to know if her memory of timing is right. The battery is dead and the tires look deflated. It's only got ~100,000 miles on it. I'm planning on getting it towed straight to the mechanic, but also wondering if I can just replace the battery, put some air in the tire, and drive it home first or would that just cause more problems? I don't have indoor marking so the car will have to stay outside and endure the winter Just out of curiosity, are you related to the current owner in any way possible? Quote
architect Posted June 24, 2025 Author Report Posted June 24, 2025 (edited) The car runs great so far. I've driven it back to the previous family to show off that it's still running, which they hare happy to see. One issue is that the tail brake lights do not work, but the third small light on the windshield does. I read some other similar issues, and it sounds like the "multi function switch". I think other places have called it a "combo switch". If I pull the signal switch back slightly, but not all the way to engage highbeam, then the brake lights will work. Does anyone have the particular part model or "proper" name for this part? I'm also seeing that it's call "turn signal" switch. I'm not very car-inclined. I'm assuming is discontinued and hoping there's an aftermarket solution. Edited June 24, 2025 by architect pwmin 1 Quote
architect Posted June 24, 2025 Author Report Posted June 24, 2025 Oh, when the car first starts up I can't click on the shifter to get it out of park into gear. I have to wait a few seconds first, which is not a big deal, but hopefully that's not a sign of a serious problem. Quote
Black92GS Posted June 24, 2025 Report Posted June 24, 2025 (edited) 1 hour ago, architect said: The car runs great so far. I've driven it back to the previous family to show off that it's still running, which they hare happy to see. One issue is that the tail brake lights do not work, but the third small light on the windshield does. I read some other similar issues, and it sounds like the "multi function switch". I think other places have called it a "combo switch". If I pull the signal switch back slightly, but not all the way to engage highbeam, then the brake lights will work. Does anyone have the particular part model or "proper" name for this part? I'm assuming is discontinued and hoping there's an aftermarket solution. That would be the turn signal switch. Not terribly hard to replace, but you do need to pull the airbag, the steering wheel, the clock spring and the lock plate to get to it. 1 hour ago, architect said: Oh, when the car first starts up I can't click on the shifter to get it out of park into gear. I have to wait a few seconds first, which is not a big deal, but hopefully that's not a sign of a serious problem. Sounds like the Brake shift interlock is acting up. What I can't recall is whether the turn signal switch issue that causes the left/right brake lights to not illuminate correctly also causes issues with the shift interlock not releasing like it should. I'll let someone else chime in regarding that. Edited June 24, 2025 by Black92GS architect and primergray 2 Quote
architect Posted June 24, 2025 Author Report Posted June 24, 2025 48 minutes ago, Black92GS said: That would be the turn signal switch. Not terribly hard to replace, but you do need to pull the airbag, the steering wheel, the clock spring and the lock plate to get to it. Thanks that's helpful as I was wondering why I couldn't find many hits for "multi function" switch. The key fob also doesn't work despite fresh coin batteries. What could I be looking at? Took my elderly father for a ride and he is happy to see a car like this still going! primergray 1 Quote
Black92GS Posted June 24, 2025 Report Posted June 24, 2025 Just now, architect said: Thanks that's helpful as I was wondering why I couldn't find many hits for "multi function" switch. The key fob also doesn't work despite fresh coin batteries. What could I be looking at? Took my elderly father for a ride and he is happy to see a car like this still going! No problem. Pay attention when ordering a replacement though, as there seems to be different part numbers based on whether the car has column or console shift, and whether it has steering wheel controls. The key fob not working is highly likely to be bad solder joints in the keyless entry module. There is a write up on here about repairing them. Extremely common issue! primergray and architect 2 Quote
primergray Posted July 1, 2025 Report Posted July 1, 2025 On 6/24/2025 at 3:11 PM, Black92GS said: That would be the turn signal switch. Not terribly hard to replace, but you do need to pull the airbag, the steering wheel, the clock spring and the lock plate to get to it. Sounds like the Brake shift interlock is acting up. What I can't recall is whether the turn signal switch issue that causes the left/right brake lights to not illuminate correctly also causes issues with the shift interlock not releasing like it should. I'll let someone else chime in regarding that. I don't remember having any shift interlock issues when my turn signal switch was bad...but I don't usually put it into gear less than a few seconds after startup and that was about 7 years ago. architect 1 Quote
architect Posted November 1, 2025 Author Report Posted November 1, 2025 On 6/24/2025 at 3:11 PM, Black92GS said: That would be the turn signal switch. Not terribly hard to replace, but you do need to pull the airbag, the steering wheel, the clock spring and the lock plate to get to it. Sounds like the Brake shift interlock is acting up. What I can't recall is whether the turn signal switch issue that causes the left/right brake lights to not illuminate correctly also causes issues with the shift interlock not releasing like it should. I'll let someone else chime in regarding that. Now I can't even bring it out of park. I don't think it's related to the brake/turn signal switch, since I can get the brake lights to work if I pull the signal lever slightly back. But doing that doesn't help me release the shifter out of park. Seems like someone else mentioned a Shift Interlock Solenoid. Thoughts? That seems like a simpler part and something I can do quickly in comparison to the turn signal switch that I'm just living with so far. Quote
rcLord510 Posted November 2, 2025 Report Posted November 2, 2025 6 hours ago, architect said: Now I can't even bring it out of park. I don't think it's related to the brake/turn signal switch, since I can get the brake lights to work if I pull the signal lever slightly back. But doing that doesn't help me release the shifter out of park. Seems like someone else mentioned a Shift Interlock Solenoid. Thoughts? That seems like a simpler part and something I can do quickly in comparison to the turn signal switch that I'm just living with so far. that's likely what's causing your issues. that solenoid can fail, happened on my 03 GTP. Does it have a neutral release? If it does try pushing it down and see if it will come out of park. that solenoid has a little plastic disc on it that comes out, and pulls a rod that releases the interlock, when you push the emergency park release, its just manually releasing it. not a super bad part to replace if you end up having to, just not sure about finding one. architect 1 Quote
Black92GS Posted November 5, 2025 Report Posted November 5, 2025 On 11/2/2025 at 12:26 AM, rcLord510 said: that's likely what's causing your issues. that solenoid can fail, happened on my 03 GTP. Does it have a neutral release? If it does try pushing it down and see if it will come out of park. that solenoid has a little plastic disc on it that comes out, and pulls a rod that releases the interlock, when you push the emergency park release, its just manually releasing it. not a super bad part to replace if you end up having to, just not sure about finding one. I don't believe those have the manual release button. IIRC, there is a mechanical over-ride with the key. In the event of a failure, you turn the key to the "Off" position, which allows you to shift into neutral, then start the car. The 2nd gens respond in a similar manner, however I believe the console shift interlock on those is fully electric, hence the need for the emergency release button. 94 olds vert and rcLord510 2 Quote
primergray Posted December 8, 2025 Report Posted December 8, 2025 On 11/1/2025 at 7:11 PM, architect said: Now I can't even bring it out of park. I don't think it's related to the brake/turn signal switch, since I can get the brake lights to work if I pull the signal lever slightly back. But doing that doesn't help me release the shifter out of park. Seems like someone else mentioned a Shift Interlock Solenoid. Thoughts? That seems like a simpler part and something I can do quickly in comparison to the turn signal switch that I'm just living with so far. Yeah, that makes it sound even more like the brake lights are the turn signal switch in the column... 1994-2001 Gen 1 and Gen 1.5 Turn Signal Switch Replacement | W-BodyTech Forums But that shifting thing...are you able to turn the key and move the steering wheel? Can you shift out of park with the steering wheel unlocked but with engine off? architect 1 Quote
