21 minutes ago, rich_e777 said:
It had to be saved, it was going to the Jawas otherwise. All Jiggity57`s fault for posting it.
I got into a bit of a race the other day when I probably shouldnt have. I made a right turn and immediately found a speeding BMW attempting to swerve around me from a sharp corner in the right lane. I laid into the pedal a bit, chirped the tires and heard an awesome turbo wastegate PAHHTISHHHHH and left the kraut cart far into the rearview mirror. Scared the hell out of me and blew the lower hose off the turbo in the process. I love this freakin` car!
Decades after WW2 and we can still put the Messerschmitt`s in their place, just not in a P51 Mustangs.
You're welcome.
  • Like 2
  • Thanks 1
  • 2 weeks later...
149,996mi
I`m thinking about registering for a spot at the Good Guys show in Lebanon, TN next month. Its now open to all American cars `99 and earlier.
  • Like 3
  • 2 weeks later...
On 4/11/2024 at 10:02 PM, jiggity76 said:
You're welcome.
Thanks again, we`re going to have to get all these cars together at some point so you can check it out. Its been years since a meet up happened.
Shes going to the show, May 17-19. I`m going to try to find some seat covers that fit good and might give that dash cover a shot on RA to hide the crack. The paint might not be in the best of shape with the orange peel and fading wheel arches and I`m not the best at talking with strangers but it should be a good time.
GM Nationals?
Its in Carlisle Pennsylvania this year, about a month an a half away. I`d love to bring this but I dont trust it on a 18 hour trip there and back home just yet.
  • 3 months later...
I might have to replace the sunroof seal surrounding the glass, a section of it is catching and starting to come apart. Is there a P/N for that seal or a good universal size to use?
I think you're talking about the black seal that surrounds the glass on the exterior side or the edge that meets up flush with the roof when the glass is closed?  If so, it's not available anymore.  The GM part # is 12392898.  Not sure of any aftermarket kits being out there but then again, I haven't looked that hard into it.
I would start with your local glass shop and see if you find some answers there.  This is what I would do if it were my car and situation.
Edited by jiggity76
Yep sounds like it, thanks for the P/N too. A few sort of sketchy websites show one in stock so I`ll reach out and cross my fingers.
Unfortunately in Nashville those glass people are really not that knowledgeable nor care to look for something if it takes more than 5 minutes. There are piles of discontinued seals and a huge selection of universal stuff just collecting dust in their warehouse too. Huge business opportunity in Nashville if I knew how to start up a company like that.
  • 8 months later...
  • 1 month later...
My nephew and took her out last night and he's working on making content for the interwebz. A few of the better pics he took at the same place I took the convertible years ago.
Unfortunately the P side rear caliper seized up and cooked the nearby rubber parts. That and most of the rear suspension is crispy from being up in Jersey so shes parked for now while the parts roll in.
  • 11 months later...
After taking a closer look at the rear brakes it seemed someone only replaced the drivers side parts once upon a time and left the passenger side caliper and bracket original. So just to be sure I replaced both sides with all new calipers, brackets, ac delco pads, and hardware all greased up in the right spots. Then the P/S fluid started going foamy on me so I bought all new parts for that system and found... :facepalm:
One doesnt need to fish out and back in brand new P/S lines if the F`n pump to reservoir O-ring seal was the culprit all along... She's almost ready.
uuuuuuuuuhhhhhhhhh..........what brackets?
1st generation rear discs prior to '94 don't make use of a bracket, the caliper is fastened directly to the rear knuckle casting...sooooooooo what have you got there?
Sorry about that, I should have reread that last post a bit better. After clocking out for the day, getting into car stuff then hopping on the PC I`m worn out.
While I was focusing on just the rear brakes and what caused the issue I wound up replacing the front brake parts as well. Went all against "if its not broke don't fix it" but those front piston boots and brake lines were on borrowed time.
  • 4 months later...
  • 1 month later...
TBH I thinks its going to take exactly that, but not before this and then might as well replace that. But then oh if we`re going this far might as well go all in or it wasn't worth putting in at all because it just isn't the right way. Le Damnit`e
Its under a cover for the most part while I sort out some non-brake related issues, highly recommend Seal Skin for covers.
