rich_e777 Posted March 25, 2023 Report Share Posted March 25, 2023 I`ve found a near perfect front drivers seat for my `95 Cutlass Vert at the salvage yard, problem is that its motorized and the JY wont allow me to even buy a used battery from them to use to power it forward so I can remove it. Is there any way to manually get the seat to move forward to access the rear mounting bolts? Quote Link to comment Share on other sites More sharing options...
Solution Raffaelli Posted March 25, 2023 Solution Report Share Posted March 25, 2023 You have a 18v Milwaukee or Ryobi type drill battery? Schurkey, rich_e777 and White93z34 3 Quote Link to comment Share on other sites More sharing options...
GTP091 Posted March 25, 2023 Report Share Posted March 25, 2023 Some yards will have a booster pack they will bring over to temporarily power up the car. rich_e777 1 Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted March 25, 2023 Report Share Posted March 25, 2023 25 minutes ago, Raffaelli said: You have a 18v Milwaukee or Ryobi type drill battery? This is a good way to do it. Find whatever fuse powers the seats and have some wires ready to go. That way you can connect the battery to the pins in the fuse block. As long as the wires in the car are still intact, that battery should power up the seat and you will be able to move it around. That's how I used to test electronics at the yard. Just find the fuse and put power in there and check on whatever. Radio, cluster, ect... rich_e777 1 Quote Link to comment Share on other sites More sharing options...
rich_e777 Posted March 25, 2023 Author Report Share Posted March 25, 2023 Well I`ll be a suck egg mule I didnt think of that at all. I just tested it on the seats I have and it`ll work perfectly. Thanks guys! Raffaelli and 94 olds vert 1 1 Quote Link to comment Share on other sites More sharing options...
stantmann Posted May 21, 2023 Report Share Posted May 21, 2023 I had the same issue, but it ended up being really simple, at least for the international cutlass I was working on. Most passenger seats are manual. Start there and take that seat out first since you don't need a power source. Once it is out, the passenger side will have an unused power connector exposed on the floor. Connect the orange wire to your dewalt battery, and the black wire to the opposite side of your battery. If you have alligator clips, they would probably work best. Now that you connected power, go over to the driver side and use the buttons to move the seat forward/back. 94 olds vert 1 Quote Link to comment Share on other sites More sharing options...
rich_e777 Posted May 25, 2023 Author Report Share Posted May 25, 2023 Thanks dude but I got them out a month or so ago. I was able to get alligator clips to hold on the disconnected harnesses under the seats to move them where I needed. Quote Link to comment Share on other sites More sharing options...
