Hi, I am looking for this vacuum harness or the throttle body connector from any 2.8 or 3.1. But W-Body’s will help. If you can let me know if you got any I would appreciate it. I am in the process of rebuilding my harness because the plastic line is cracking badly.
The connector at the throttle body is toast. I cannot locate one.
Here is a photo of one intact.
Edited by 89-W-Body-Regal
What years will work for you? I have some parts from a 1990 Chevrolet Beretta that had the 3.1L engine.
I think Beretta used a 3 port. He needs a 4 port which W bodies used.
What do you mean by ports?
W bodies have 4, N-L bodies only had 3.
Edited by ManicMechanic
18 hours ago, ManicMechanic said:
W bodies have 4, N bodies only had 3.
Yes that’s exactly what I was thinking when you say that. Thanks for confirming
A bodies are 4 port too, so there's another avenue.
Yeah I need the Tbi connector really bad or it's gonna start leaking. The hard lines I am not using anymore. I am going to use rubber hose line.
Someone on facebook in the fwd group we are in said auto parts stores used to sell them. But they are so hard to find. I wish dorman would make them. They make the elbows. I got two packs.
  • Like 1
  • 1 year later...
Hey do u still have parts ?
  • 9 months later...
If you still have the harness from beretta I’d buy it from you
  • 3 months later...
Dorman does sell universal hard vacuum tubing.  You can probably bend it to shape with a heat gun.  Years ago, I just put heatshrink tubing over the cracks.  Looked like an obvious fudge-fix, but worked fine.
