ManualOldsOnly Posted May 20, 2021 Report Posted May 20, 2021 Hey all need help on my clutch release bearing for my 284. I need to either source a correct one or find a replacement option such adapting a similar one. Thanks Quote
White93z34 Posted May 20, 2021 Report Posted May 20, 2021 A off the shelf clutch kit will come with one. Quote
Bake82 Posted May 21, 2021 Report Posted May 21, 2021 On 5/19/2021 at 11:05 PM, White93z34 said: A off the shelf clutch kit will come with one. And if you’re that far probably best to replace the clutch anyways! if you must only get the bearing. I wonder if spec would sell seperately? Quote
carkhz316 Posted May 24, 2021 Report Posted May 24, 2021 They won't. I've asked them in the past. It seems the only way is to get one in a clutch kit. However, they all appear to be the same bearing, so just get the cheapest kit out there and save the clutch for a rainy day. Quote
ManualOldsOnly Posted May 24, 2021 Author Report Posted May 24, 2021 I actually may have found it. I called spec and they told my the bearing number was a N1759SA borgwarner which crosses to a 614069 timken that was able to source. The reason I didnt get a a whole kit is cause I got my clutch & pressure plate rebuilt along with getting my flywheel resurfaced and it was only $80 vs. The expensive kit. However I didnt realize it was so hard to find the damn bearing. vipmiller803, carkhz316 and pwmin 3 Quote
