Beau Posted August 9, 2019 Report Posted August 9, 2019 Hello I'm a new member here... I bought the car a year and half ago from original owner. Her son was a GM mechanic and had a binder of every service from 1994. When i bought it I changed all the fluids and filters, plugs and wires. It ran like a new car. So quiet i couldn't here it at idle in the car. I drove the car to work and it drove great, drove it home and the same. I start it the next morning and the motor was clattering loudly so I shut it off. The oil is full, the coolant was low about 2 cups. It didn't over heat or even get hot. What could have gone wrong over night? Its crazy it drove perfect to my house and super quiet, and the next morning its chattering. I ran it for maybe 3 seconds and shut it down. I poured seafoam in oil and started it and the same, waited till the next day to let it do its thing and start it, same noise so I shut it down fast. Should I let it run and hope it was a clogged lifter? I just dont want to ruin a low miles taken care of motor. Thanks for any help Quote
digitaloutsider Posted August 10, 2019 Report Posted August 10, 2019 A Ciera is technically an N-body, but the 3100 is generic enough. Being that the coolant is low, I'd look at the engine oil. See if it looks like a milkshake. If it does, the loud clattering could very well be indicative of a spun bearing. Quote
Amanita Posted August 10, 2019 Report Posted August 10, 2019 (edited) Can you record the sound for us? I just went outside and recorded my 3100, though my engine was warm when I started it up. Â Edited August 10, 2019 by Amanita Quote
Beau Posted August 10, 2019 Author Report Posted August 10, 2019 The oil has around 500 miles on since the last change and it looks like new oil. No moisture under oil cap. No coolant has made its way into the oil. I will make a video of the noise tonight or tomorrow sometime. Thanks  Quote
Beau Posted August 10, 2019 Author Report Posted August 10, 2019 I looked for a N-body.com and couldnt find anything or anything on here about a nbody section. Do you know where I could find?Thank you   Quote
digitaloutsider Posted August 11, 2019 Report Posted August 11, 2019 I think there used to be an N-body forum somewhere. I guess I forgot that much like these cars, no one really cares about them anymore. You're welcome to hang out here and ask these sorts of questions, but things move pretty slowly over here. Also check out the www.60degreev6.com forums. Beau 1 Quote
digitaloutsider Posted August 11, 2019 Report Posted August 11, 2019 Also, I am such a fucking idiot, I'm sorry. I had Cutlass Calais in my head. The Ciera is an A-body; they still have a somewhat active community over at A-body.net. pitzel 1 Quote
Cutlass350 Posted August 11, 2019 Report Posted August 11, 2019 4 hours ago, digitaloutsider said: I think there used to be an N-body forum somewhere. I guess I forgot that much like these cars, no one really cares about them anymore. You're welcome to hang out here and ask these sorts of questions, but things move pretty slowly over here. First, as you said, the OP's car is an A-body, not an N-Body. My two Achievas are N-body cars. Fwiw, there aren't any really active forums for N-Bodys. Since the car is an Olds, a "possible" forum is at: https://oldsmobileforums.com/forums/index.php Note, as much as *I* am a die-hard Old's fan (I currently have three :)), I don't check out those forums anymore. Imho, just about every new post was "how do I fix the car, but not spend any money at all". Imho, in other words, they were really saying "I'll send this car to the crusher the second that I have to spend any real money on it". Imho, spend money and do maintenance, or get another car and hope that it lasts. Fwiw, I agree, I think that the OP should be welcome here. This one of the few active forums for older GM cars. There aren't a ton of posts. But, imho, that's a good thing. :) Also, I agree that we need a video with sound. It might be something simple. Or, it might not be.  Quote
Beau Posted August 14, 2019 Author Report Posted August 14, 2019 My mother has been in hospital since friday i haven't had the chance to record sound yet but im hoping to by Thursday at the latest. Thanks everyone Quote
Cutlass350 Posted August 16, 2019 Report Posted August 16, 2019 I hope that your mom gets better soon. Record and post the video when you have the time. No rush.  Quote
55trucker Posted August 16, 2019 Report Posted August 16, 2019 Not familiar with the Ciera instrument cluster, is there an oil pressure gauge or just an *idiot light*? Do you see anything to suggest that there is little or no oil pressure? Â Quote
Pontiac6KSTEAWD Posted August 16, 2019 Report Posted August 16, 2019 www.A-Body.Net Its not as active as it used to be. But its still alive and kicking. I am the forum moderator over there.. Come on over! Would have to hear the sound the motor is making to give an honest answer. Quote
Beau Posted November 20, 2019 Author Report Posted November 20, 2019 Sorry it took so long. I've been dealing with alot lately. Any help is greatly appreciated, thank you all 20191120_091552.mp4 Quote
Cutlass350 Posted November 22, 2019 Report Posted November 22, 2019 (edited) That sounds like a bad lifter to me. Change the oil. Put in a good multi-grade synthetic. My go-to oil is Mobil-1 synthetic. Fwiw, my Quad 4 engines always had load lifter sounds. Iirc, they are both near/past 200K miles. A bad, fast leak down, lifter isn't the end of the world. That noise is the valve *slamming* against the valve seat. Depending on the length of time, and the miles, you'll put on the car, you "could" ignore the bad lifter. If you have experience working on cars/engines, _in general_, replacing lifters isn't "horrible". I do not know the specifics of that engine, nor the common "PITA" things that can break/be-a-pain when replacing the lifters. Imho, don't replace the lifters yourself, if you need the car "right away". You may have to order gaskets, sensors, etc. Fwiw, on my '77 Olds 350, I put in a "3/4ths" race cam (hey, that's what it was called). I was young and foolish. It was WAY too much cam for the engine. I put on Rhoads lifters to "tame" the cam enough to get "okay" vacuum and performance with city driving (that I did ~95% with that car). Rhoads lifters are "fast leak down" lifters (like a bad lifter :)). However, the purpose is to lessen the valve lift and duration at low rpms (like idle). But, at higher rpms, the lifter doesn't have a chance to leak down, do the full effect of the cam is used. It's a mechanical way of having variable lift and variable duration for the cam. I had stainless steel valve, and custom valve spring forces(higher) for the cam. I ran Rhoads lifters for well over a dozen years in my Olds 350. I put well over 100K miles on the engine with those lifters. The heads and valves were fine. But, again, mine were not stock valves or valve seats. However, most people back then used the stock heads. For a head/valves in good shape, imho, lasting 50K+ miles, using Rhoads lifters, wasn't even a concern. The video below gives a good idea of what Rhoads lifters sound like. https://www.youtube.com/watch?v=R0s_nwahCBU 1970 El Camino 383 Stroker with Rhodes lifters Dick Fitzwell Good Luck! Edited November 22, 2019 by Cutlass350 Beau 1 Quote
Pontiac6KSTEAWD Posted November 22, 2019 Report Posted November 22, 2019 Had me worried.. In your OP you said clattering, im thinking Flex Plate, or rod... But thats just lifter noise. As stated, you could continue driving as is, or get it fixed. The engine will last longer, and perform better if repaired. Beau 1 Quote
Beau Posted November 23, 2019 Author Report Posted November 23, 2019 The oil was changed about 5 months back and only had about 450-500 miles on and then this sound started out of no where. I put the exact oil the owner guide calls for and filter, its also perfectly filled. It was actually worse when the noise first started and the 4 time I started it after to show friends and my brother the noise. Somehow after sitting a couple months it has gotten 3/4 quieter. I did empty the oil a little and added seafoam to the crank case like my brother said to, so maybe that helped ? Im not an online person so do you mind telling me what fwiw mean and lirc? Thank you guys I am very appreciative of you time and help Quote
Cutlass350 Posted November 24, 2019 Report Posted November 24, 2019 (edited) You can use google for any abbreviation that you're not familiar with. Google does a pretty good job with those. You may have to add "slang" or "online meaning" in the search term. https://www.google.com/search?q=fwiw === Search Results Featured snippet from the web FWIW. acronym for "for what it's worth". Used mainly in computer-based conversation (instant messaging, email, text messaging, etc.) IANAL, but FWIW I think you're right about contract law. See more words with the same meaning: Internet, texting, SMS, email, chat acronyms (list of).Aug 23, 2012 === https://www.google.com/search?q=lirc+meaning+slang ========== Search Results Featured snippet from the web Meaning. IIRC. If I Read Correctly. IIRC. If I Recall/Remember Correctly. ========== Seafoam is a so-so treatment. For oil, I'd do an oil change after ~100miles. Lifters for OHV (OverHead Valve - older style heads/engines) go all the time. That car is old. That engine is old. The parts are old. Parts like lifters, fuel pumps, alternators, starters, etc can go at any time, because of their use and/or age. You didn't list what part of the country you're in. To help with weak lifters, use the heaviest oil that you can for your area and the time of year. Also, after ~3,000 miles, all oils start to show their "age". It varies depending on many factors. In New England, during the Spring and Fall, the daily highs and lows often result in condensation. Unless a car is kept in a sealed and climate controlled room/garage, then there's a good chance that the there will be condensation in the oil pan, even if the car is never run. Also, there will be some moisture in the oil pan, every time an engine goes from being ambient temperature to being fully warmed up, then back to ambient temperature. There are many ways in which an oil "ages". Imho, change the oil ever ~3,000 miles and at least every 6 months. Imho, in New England, every 3 months is better. https://www.google.com/search?q=Imho ====== IMHO is an acronym used mostly in texting, email, and social media that means in my humble opinion. It was first used in the 1980s in online forums, and decades later, some began erroneously attributing the H to the word honest ====== Good Luck! Edited November 24, 2019 by Cutlass350 Beau 1 Quote
Beau Posted November 24, 2019 Author Report Posted November 24, 2019 Thanks for all the my friends, greatly appreciated! I'm from florida, is 10w30 the heaviest I should go to? When you said change oil after 100 miles, does that mean drive it with that tapping noise? If I didnt have so much money and time invested in maintenance in this, i would have junk yard it by now. I have changed out all suspension, calipers, rotors, water pump,thermostat, alternator, coils, plugs, wires, and a bunch of sensors. When I bought it, it was from an older woman that let it sit for a long time and all the fluids were funky. The son was a mechanic and had a folder logging all the maintenance from New. On another oldsmobile forum a guy told me to check exhaust for leak and to make sure plugs were seated, he said to him it sounded like one of those? What your thought on that? Thanks again have a blessed day Quote
Beau Posted April 22, 2020 Author Report Posted April 22, 2020 I just got around to messing with the cutlass again today and started by draining the oil in a brand new oil collector and then in clear container to see if maybe there was something. The first 15 seconds it poured out nice and clean and then it took about 5 min for about 4 cups of sludge. I took the filter out and it was clogged with sludge. I took the valve cover off and its not sludged up. How is the lower motor sludged up but the heads arent? Is this motor salvageable? It wasnt ran long at all with the tapping. Could I take the oil pan off and clean the oil pump and screen and fill it with some strong motor flush or is this motor need to be taken apart? Thanks Quote
55trucker Posted April 22, 2020 Report Posted April 22, 2020 56 minutes ago, Beau said: Could I take the oil pan off and clean the oil pump and screen...... Couldn't hurt assuming you're comfortable doing so....whatever has been done to the engine is done.....clean out the pan & look for debris, pull off the pump and disassemble it to clean it out as well. When the pump comes down more than likely the pump drive shaft will fall out as well, unless it is gunked up into place. You can't see the drive shaft at all, it is hidden up above the rear main cap assembly in a hollow passage. It is driven off the camshaft drive gear. If you see a world of sludge in the pan you can bet that the oil passages will be in the same condition and those passages feed the crank & cam bearings. Quote
Beau Posted May 6, 2020 Author Report Posted May 6, 2020 Today I took down the pan, and cleaned out a good 1/4'' of sludge stuck to it. I took down the oil pump and cleaned it and filter that was clogged. cleaned all the sludge i could see. filled it with new oil+filter and same tapping. Im about to dump all the oil out and put in the old oil filter and fill the motor with kerosene and turn it over a bunch without starting and hope it clean passages. Anyone know of any extreme motor flushes? Its junk yard bound so any last ditch efforts before. I hate that this car is mint like 9.8 out of 10. have over $3k in maintenance in the first 3 month of owning thinking it would last since it was so low mileage. I still have no idea how it sludged up Quote
Pontiac6KSTEAWD Posted May 7, 2020 Report Posted May 7, 2020 I would not suggest old filter, or kerosene. I would suggest that you drain 1 quart of oil, and replace it with 1 quart of transmission fluid. It is a very heavy detergent oil, while still having some lubrication properties. Run it for about 50 miles, and then perform an oil change. Quote
55trucker Posted May 7, 2020 Report Posted May 7, 2020 On 5/6/2020 at 12:18 AM, Beau said: I still have no idea how it sludged up Serious lack of maintenance. Previous owner wasn't changing the oil at the proper interval. Attempting to *clean* out the internals over a very short period of time isn't going to happen. Not knowing the history of the car, seems apparent that the engine has been run in that state for some time, a look at the bearing journals is warranted, the lifters are more than likely gummed up, the intake could also be choked via the PCV valve and the intake snorkel crankcase circulation tubing. but try what you can before you condemn the engine. Â Quote
Beau Posted May 8, 2020 Author Report Posted May 8, 2020 I bought the car from an older woman that was the original owner. when I bought it I got a binder with everything done from new. She for sure had it maintained at a dealer and the oil was always done on time and logged. When I bought it I had the oil changed at the 3k mark and everytime after. I never dogged the car, it never leaked fluids anywhere. the whole motor is clean . This car really irritates me, I paid top dollar for it since it had 76k miles and original owner and all the documented care. I also put almost 4k$ in upgrades and maintenance thinking I was gonna have a long lasting car. Lasted 9 months lol Quote
