oldmangrimes Posted November 6, 2018 Report Share Posted November 6, 2018 (edited) I had a bad start to my day, but I'm very lucky it could have been much worse. Thank God nobody was hurt and I didn't cause an accident. I had just replaced my lower engine mount a couple days ago, which was causing the engine to move around a lot. Unfortunately it wasn't my only problem, and this morning when I tried to drive the Cutlass to work, I made it about 10 miles but after taking a 40mph sweeping curve to the left, on a two-lane road, my right front suspension failed. Luckily I had straightened out of the turn, otherwise I would have rolled the car down into a ditch, or worse. I tried to steer to the left into a driveway off the road, but my forward momentum wasn't enough to get there, obviously dragging the wheel sideways, jammed into the wheel well. I was blocking most of the road, but was able to get out of the car and flag down oncoming traffic. Luckily one of the first guys that stopped to help had some flares and set them up. Another guy with a truck and a tow rope hooked onto the A-arm and dragged me 20 feet off the road into the driveway. I was a few miles from town, so I had to wait a while for a tow-truck. The sheriff came, added a couple flares, wished me luck, and left. The first tow-truck was a flatbed, and the guy tried but couldn't get the car up onto the flatbed without causing more damage, so he called in another standard lift-truck to do the job. Eventually that guy got the car secured and towed it back to my house and he managed to place it in my garage, where it will sit while I decide what to do with it. I haven't had more than 2 minutes to look at it up close, I had to run to work. The ball joint popped out, the axle was destroyed, the transmission dumped a ton of fluid, (which while the car was being towed ran back along the entire undercarriage and coated everything back to the rear bumper), the tire is probably not safe to use, and I'm sure a ton of other parts would need to be replaced. The hub has less than 5k on it, but it took a big side-load so might be shot. The brake lines were stretched, the plastic trim on the wheel well was slightly damaged, the front strut/spring assembly was twisted out of place, the tie rod was damaged, etc. Of course I SHOULD scrap the car, it's got 235k miles and has some other problems that aren't related. But I really don't WANT to get rid of it, it's got a new top and I'd planned on keeping it forever. I'm going to take a few days to calm down and think about it, and I can leave it in my garage for awhile. But we only have one parking spot in my attached garage and my wife won't be happy about going out in the weather all winter. The good news is that the belly stayed off the pavement, the fender metal seems ok, and the car might be savable. I can manage the bolt-on stuff, but I'm mostly worried about the transmission/axle. And of course since this failure happened, I'll replace everything on the drivers side too, as I'm sure it all is due for replacement. Unfortunately I won't have time to dig into it and assess anything until after Christmas, so I'll post an update in a couple months. I don't have the money to take it to a shop now, although I may have to eventually if I can't do it myself. In the meantime, I'd appreciate any advice from you guys. This isn't a show car, just a driver, so I'm looking at ways to get it safely back on the road in time for next summer for less than $1000. I can take other pictures if you want to see different angles, but I won't have time for much disassembly as I've got another car to drive and other projects screaming for my time and money. Edited November 7, 2018 by oldmangrimes clarifying Quote Link to comment Share on other sites More sharing options...
Amanita Posted November 7, 2018 Report Share Posted November 7, 2018 I'm glad to see that you're doing alright, that definitely could have gone a lot worse. I wish you the best in repairing this car and hope to see it all fixed up. Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted November 7, 2018 Report Share Posted November 7, 2018 Been there, Totally fixable. Might have to pound the strut tower slightly to get it straight but otherwise, a control arm, axle, fill the trans and you're back on the road. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted November 7, 2018 Report Share Posted November 7, 2018 Ditto, probably just popped the CV out of the tranny. Assess the damage and I bet you'll find a leisurely day's worth of labor and a a few hundred dollars in parts. From the picture I'd say CV and Ball joint, maybe a tie rod and if the tie rod is bent do the outer tie rod end because it'll be off anyways. Quote Link to comment Share on other sites More sharing options...
pontiac6ksteawd Posted November 7, 2018 Report Share Posted November 7, 2018 Totally repairable. Maybe 300 bucks if you buy the parts new.. And about 75 if you junk yard it. If you do decide its not worth it, let me know.. Been wanting a cutty vert with the 3100/3400 and not the LQ1. Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted November 7, 2018 Report Share Posted November 7, 2018 This is a good reminder to others to check your ball joints. oldmangrimes, digitaloutsider, cheatah faheatah and 1 other 3 1 Quote Link to comment Share on other sites More sharing options...
Imp558 Posted November 7, 2018 Report Share Posted November 7, 2018 There's A LOT that should be checked periodically. Ball joints at the top of the list, subframe bushings should be up there too. Even living in a state with mandatory safety inspection I find stuff from time to time. oldmangrimes 1 Quote Link to comment Share on other sites More sharing options...
Human Posted November 9, 2018 Report Share Posted November 9, 2018 Ouch! Glad no one was hurt. That's the most important thing. Hope you can get her back on the road. That looks almost just like my '95 'Vert. I'd be pretty sick if that happened to mine. oldmangrimes 1 Quote Link to comment Share on other sites More sharing options...
GabsOlds Posted November 10, 2018 Report Share Posted November 10, 2018 That was terrible! Must have been scary too! Good no one was hurt. Like everyone says, it won't take much to fix. Good luck with the repairs. You should be back in business by next summer. Quote Link to comment Share on other sites More sharing options...
GTP091 Posted November 19, 2018 Report Share Posted November 19, 2018 Rough deal man. Real ass kicker. Glad you didn’t lose the drivers side and get pulled into a head on. The parts won’t be bad cost wise so the fix will be easy enough if you know how to do suspension work. Hopefully you find the fender is in good shape and not twisted or pushed into the door? Get the car up on jack stands and take a good look at what you’ve got yourself into. Quote Link to comment Share on other sites More sharing options...
oldmangrimes Posted February 11, 2019 Author Report Share Posted February 11, 2019 I've got the passenger side done, but the control arm bolts were seized to the bushing sleeves on the driver's side. Penetrating oil and many swings of a sledgehammer worked on the passenger side bolts, but that wasn't enough for the drivers side so I gave up and had to cut the bolts. One problem I ran into was that was my Ryobi battery-powered sawzall has a long body and I couldn't get a very good angle for one of the cuts that's closest to the axle, I kept bending the saw blades. So I had to use my angle grinder and cut off chunks of the control arm until I had enough clearance to get all the way through the bolt. I had to make multiple cuts before it finally cut through (and I get a little nervous with showers of sparks from the angle grinder landing on an oil-covered engine) but I finally got it out of there. Now all I have left to do is the drivers side tie rod, install new brake lines, torque all the new bolts, refill the transmission, clean off the leaked transmission oil from the exhaust (because I don't want to smell that or start a fire) and hope it starts and runs. I'm guessing I'll get it done by early March. pitzel 1 Quote Link to comment Share on other sites More sharing options...
Imp558 Posted February 11, 2019 Report Share Posted February 11, 2019 The A-arm bushings were bad? That one doesn't look bad. I mean obviously it's not repairable at this point but it doesn't look worn out. Quote Link to comment Share on other sites More sharing options...
oldmangrimes Posted February 12, 2019 Author Report Share Posted February 12, 2019 I don't actually know if the A-arm bushings were worn out. I just figured that since I was taking everything apart that this was my chance to put new ones on. After 24 years and 225k miles, I figured that any rubber in the suspension would be due for replacement. But I've never done control arms before, and if I would have realized how much of a pain it was to replace I probably wouldn't have done it. I probably won't notice any difference in the handling, but if I DIDN'T replace the control arms, then I'd always wonder "what if". The steering has been a little sloppy, but that's probably due to the tie rods and the fact that it's a convertible w-body. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted February 12, 2019 Report Share Posted February 12, 2019 The factory A-arms are nice, ball joints and bushings are replaceable. Quote Link to comment Share on other sites More sharing options...
oldmangrimes Posted March 11, 2019 Author Report Share Posted March 11, 2019 She's back on the road! After a long winter of fighting rusty bolts, I finally got her back together yesterday. I carefully drove her around the block once, and she seemed to drive and shift fine. I haven't noticed any leaks from the transmission or the brake lines. I'll try a longer drive tonight after work and see how it goes. Parts replaced: Passenger side only: Axle. Both sides: Control arms, tie rods (inner and outer), ball joints, flex brake lines. Parts saved: Fender (I straightened the bent lip). Wheel well trim and lower cladding were slightly damaged but I reinstalled them. TBD: Passenger front tire and hub. The tire held air all winter, but I need to drive at higher speeds and go around corners to evaluate the hub and tire. Total cost: About $400 including tools. Time spent: I don't want to think about it, probably 50+ hours if you count watching videos and buying tools. It doesn't sound like much, but I found ways to make the project take forever. It was my first time doing any of these jobs on any car, so it was a slow learning curve to figure out what technique to use. I often would only have two or three hours a week to work on it, so it dragged on and on. I tried to save money by using the wrong tool for the job a few times, which just ended up with wasted time and frustration until I would give up and drive to the store and buy the right tool. Once I had the right tool and the right technique, each job wasn't bad. Moral of the story: Buy the right tool! digitaloutsider, Amanita, rich_e777 and 2 others 5 Quote Link to comment Share on other sites More sharing options...
Imp558 Posted March 11, 2019 Report Share Posted March 11, 2019 Testing hub assemblies is easy. Jack the car up, grab the wheel at 12 & 6, push with one hand and pull with the other and if you can rock the wheel at all the bearing is bad. Hub assemblies are not hard to replace and all four should be checked periodically. Early warning sign is a sound sort of like a plane taking off while driving. Quote Link to comment Share on other sites More sharing options...
Amanita Posted March 11, 2019 Report Share Posted March 11, 2019 Wow, Good job! Glad to see you got it working again, no doubt most people would've sent it straight to the scrapyard after that sort of accident. oldmangrimes 1 Quote Link to comment Share on other sites More sharing options...
oldmangrimes Posted March 11, 2019 Author Report Share Posted March 11, 2019 Yeah I've replaced all four hubs over the years already. The 12 and 6 method has never worked for me, I've never been able to feel any movement with the car jacked up, even on the hubs where I've heard the humming/roaring sound. Quote Link to comment Share on other sites More sharing options...
MemphisMan Posted March 11, 2019 Report Share Posted March 11, 2019 Super job getting her back on the road! Really glad to see the time and effort pay off for you! Quote Link to comment Share on other sites More sharing options...
pontiac6ksteawd Posted March 14, 2019 Report Share Posted March 14, 2019 Looking great! Quote Link to comment Share on other sites More sharing options...
oldmangrimes Posted March 15, 2019 Author Report Share Posted March 15, 2019 Got the alignment done today at a new alignment shop near me. It's a tiny place with a single bay. It's run by a young guy in his 20's, I think it's a spin-off of the tire shop next door. Anyway, when I pull in he looks at my vert and says "what kind of car IS that?". I tell him and he says "oh, I've never done an alignment on an Oldsmobile before". Wow. He said he'd been doing alignments for a year, so that's hundreds of cars. Here in Gresham Oregon, Oldsmobiles are not common and it's mostly Asian cars or pickup trucks. I still see Oldsmobiles running around, but I think they are mostly being driven into the ground by the fourth owners and they wouldn't bother getting them aligned. Side note: I noticed that sitting all winter caused my rear caliper to drag, and it sounds like a front wheel bearing is making noise, as I feared. Oh well, the battle continues. . . pitzel 1 Quote Link to comment Share on other sites More sharing options...
Cutlass350 Posted March 16, 2019 Report Share Posted March 16, 2019 On Friday, March 15, 2019 at 3:13 PM, oldmangrimes said: he says "oh, I've never done an alignment on an Oldsmobile before". Fwiw, there's no such thing as an Oldsmobile vehicle. That's a BS myth - just like the $2 bill! Congrats on getting the car back on the road! pitzel and oldmangrimes 2 Quote Link to comment Share on other sites More sharing options...
Human Posted May 15, 2019 Report Share Posted May 15, 2019 (edited) Yeah, I got the oil changed in my '95 'vert last week and the guy down in the pit thought he was working on a Pontiac Bonneville--not a Grand Prix but a Bonneville. Business was slow so he came up and we chatted for a couple of minutes. He was in his early-to-mid twenties and thought any car older than a 2000 model was a "survivor". He said he's working on fixing up an "old school" Saturn coupe. As a community college professor, I find the perspective of the younger generation to be an endless source of amusement. Edited May 15, 2019 by Human oldmangrimes 1 Quote Link to comment Share on other sites More sharing options...
oldmangrimes Posted May 15, 2019 Author Report Share Posted May 15, 2019 28 minutes ago, Human said: Yeah, I got the oil changed in my '95 'vert last week and the guy down in the pit thought he was working on a Pontiac Bonneville--not a Grand Prix but a Bonneville. Business was slow so he came up and we chatted for a couple of minutes. He was in his early-to-mid twenties and thought any car older than a 2000 model was a "survivor". He said he's working on fixing up an "old school" Saturn coupe. As a community college professor, I find the perspective of the younger generation to be an endless source of amusement. Age is relative. When I was in high school in 1992, I was driving a 1972 Chevelle and I thought it was an "old" car because it was 20 years old and older than most of my friends' cars. Now my '95 vert is 24 years old, so I guess I shouldn't be surprised that young people think it's old and don't know what it is. Unfortunately my vert is back in my garage, even though I changed the wheel bearing it still sounds bad. There are multiple sounds going on, I need to do some investigating before driving it again. I'm suspicious of (in no particular order): 1. The transmission mount (slight clunk when shifting from Park, the bottom motor mount is new last year but I've never changed the transmission mount) 2. The other three wheel bearings (I've changed them all in the last few years, but the new humming wasn't eliminated when I rotated the tires and changed the front passenger side wheel bearing this year). 3. The transmission itself (assuming #1 and #2 don't fix all the sounds). Having the driver's axle yanked out while at speed last fall couldn't have been good for it. The axle seal doesn't leak with the new axle and it shifts fine, but if it's not the the wheel bearing or the tires humming/whirring, then maybe it's the transmission? I've had wheel bearings go bad on me a few times before, but this time it sounds a little different and doesn't change as much while cornering. 4. The alignment is still off, the steering wheel wasn't straight after that kid aligned it the first time, I adjusted both tie rod ends at home afterwards to straighten the wheel but it's still not perfect and it seems to pull to the right a little. I should just pay the money for a good shop to align it instead of the cheap place. 5. The brakes (there's a periodic sound with each wheel rotation, a dragging brake might be combining with the bad alignment to cause the drift, but the wheels aren't warm after driving). 6. The steering rack. The steering wheel hasn't "felt" right since I replaced everything over the winter. I thought that the new tie rods would make the steering feel tighter, and it does a little, but it just feels "off" now. The steering "weight" feels inconsistent now, to the point it makes me worried while cornering sometimes. I don't have the time or money to replace the steering rack this summer, maybe next winter I will. Power steering fluid level is ok, pump is quiet. Of course all of these could be diagnosed by a professional, and if I can't figure it out myself I may have to do that. I just have a hard time paying someone else to do stuff that I think (key word, "think") I should be able to do myself. I figure a mechanic would check out my car and basically just say "yeah everything is worn out on this old thing, plus what the hell did you do to it!?", lol. I'm honestly embarrassed to bring my 'vert to a mechanic, but that's a me problem not a car problem. Did I mention the mpg are down about 5%? That could be related, or could be something else. I'm not too worried about it, I'm guessing that whatever is making the sounds is probably affecting the mpg. Or it could be the bad EGR, but that's another discussion for another day . . . Quote Link to comment Share on other sites More sharing options...
MemphisMan Posted May 17, 2019 Report Share Posted May 17, 2019 I understand the thought of thinking you should be able to do it by yourself. I suffer from the same thing lol. oldmangrimes 1 Quote Link to comment Share on other sites More sharing options...
