Crimson Fury Z Posted June 4, 2018 Report Share Posted June 4, 2018 This doesn't pertain to a W, but I'm not getting any bites on the Buick forum. My brother has a 97 LeSabre with a non theftlock tape/radio. The deck no longer works and wants to find a stock CD radio. Aside from dealing with unlocking a theftlock unit, should it be drop in replacement? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted June 4, 2018 Report Share Posted June 4, 2018 most of the 1.5 din units should pop right in. I just gave my buddy a cd player from my old 98 blazer for his 01 impala Quote Link to comment Share on other sites More sharing options...
Imp558 Posted June 4, 2018 Report Share Posted June 4, 2018 Double check the wiring if it has the same plugs so you don't end up sending power or ground somewhere naughty. Quote Link to comment Share on other sites More sharing options...
Crimson Fury Z Posted June 5, 2018 Author Report Share Posted June 5, 2018 Double check the wiring if it has the same plugs so you don't end up sending power or ground somewhere naughty. It will be from a same gen LeSabre, but I'll make sure before he would pop it in. Quote Link to comment Share on other sites More sharing options...
RPE1992GPSE Posted June 9, 2018 Report Share Posted June 9, 2018 I do believe the 97 LeSabre radio will be double DIN and have a 32-pin connector in the back, but any similar head unit should work just fine. Buick had some nice cassette/CD combo units then. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted June 11, 2018 Report Share Posted June 11, 2018 I have a stock CD player regal double din deck I'd sell Quote Link to comment Share on other sites More sharing options...
Crimson Fury Z Posted June 13, 2018 Author Report Share Posted June 13, 2018 I have a stock CD player regal double din deck I'd sell Cool Quote Link to comment Share on other sites More sharing options...
Human Posted October 15, 2018 Report Share Posted October 15, 2018 Double-din Oldsmobile head units (1994-2000) should fit in a Buick although the steering wheel controls might function a little differently. I had a Buick AM/FM/CD/cassette unit in my '95 Olds Aurora that was a plug-and-play installation except the steering wheel controls took on the functions they would have had in a Buick. The volume control was in the same place (upper right) but the temperature and tuning controls were reversed so that the tuning controls were on the lower left and the temperature was on the lower right. Instead of controlling the fan, the switch on the upper left was source and mute. It was confusing at first, but then wasn't so bad once I got used to it. Although I missed having the fan control on the steering wheel, I found I generally preferred the Buick unit over the Olds unit it replaced. I still have that Buick radio and it may well find its way into my '95 Cutlass Supreme convertible. Quote Link to comment Share on other sites More sharing options...
57lxi Posted November 9, 2019 Report Share Posted November 9, 2019 Check out Crutchfield. I got a single din radio/CD from them for my 95, Olds 88. With there free install kit, it was virtually plug and play. Quote Link to comment Share on other sites More sharing options...
Human Posted November 21, 2019 Report Share Posted November 21, 2019 On 11/9/2019 at 9:08 AM, 57lxi said: Check out Crutchfield. I got a single din radio/CD from them for my 95, Olds 88. With there free install kit, it was virtually plug and play. Yeah, Crutchfield is good for including everything you need and not charging an arm and a leg. Their telephone support is also first rate if you run into trouble. I got a Sony head unit for my (now ex-) wife's Jeep Grand Cherokee from them. It came with a face plate and wiring harness adapters at no extra charge. I taught her daughter how to solder wires when we installed it. Quote Link to comment Share on other sites More sharing options...
