wstefan20 Posted January 20, 2018 Report Share Posted January 20, 2018 I'll start by being the first to admit, this is not my idea although I may have put my personal touch on a few items. I mainly just want to share this build and hopefully help someone out along the way. If anyone is curious, just google the subject and you'll find my sources in the first few links and videos. I've been chasing a vacuum leak for weeks and no luck with water, carb cleaner, or propane (it was a small leak). Took me maybe half a minute to find the leak after hooking it up! I found everything local from either harbor freight, lowes, and grocery store, other than the nichrome wire. You might find a local supplier for the wire at an e-cig shop, but it's like $5 with free shipping on ebay so I really don't see the point. Over all, I think I spent around $30, although you can certainly spend less if you already have some of the materials. The regulator was the biggest cost for me. Here's a short list of what you'll need: - 1 gallon empty paint can (seriously, don't use one that's been used before, I'm not responsible for anyone dying of toxic fumes). It was around $4 at lowes.- mineral oil (fuel for creating smoke. There's other stuff you can use, but this worked fine for me, and it doesn't stink to high heaven)- air compressor (you'll use this to supply the air pressure)- 3/8" or other diameter tubing of your choosing- 3/8" barb to 1/4" npt fitting- 1/4" npt couplers (used these as nuts)- 1/4" npt regulator (some have used propane regulator. I used an actual valve cause it looked better, but the psi is too low to register so it's really not necessary)- 1/4" quick connect fitting- assorted grommets (for sealing around threads)- assorted drill bits- set of small machine screws, washers, and nuts- battery clamps- ring terminals- tiki wick replacements- 20Ga nichrome or kanthal wire cut and measure to 2 Ohms resistance (more will create too much smoke)- wire (at least 20Ga) You don't need to, but i soldered the wire onto both the ring terminals, and the battery clamps, and the same for the ring terminals and the nichrome. I installed a ball valve to help regulate the smoke, but quickly found it it wasn't necessary. Probably the best way is to have a switch on one of the terminals to turn the heating element on and off, but I found it wasn't necessary since it worked so quickly.I took two wicks and dipped downward into the mineral oil, and half of a third and used it to thicken the bundleUsed a combo of washers and nuts to clamp everything together and seal. This is where I'm bringing the current to the heating element.This is the regulator hookup to air intake. Works well, though the gague is pointless since the flow is so low. Imp558 and oldmangrimes 2 Quote Link to comment Share on other sites More sharing options...
55trucker Posted January 20, 2018 Report Share Posted January 20, 2018 hmmmmm.......do it yourself smoke machine.....I guess I come from a different era, this is MY idea of a *smoke machine* enjoy wstefan20, Imp558, jaredbonner1 and 2 others 5 Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 20, 2018 Report Share Posted January 20, 2018 I once knew a guy we called "Rob Kabob" he was totally baked and in essence was a smoke machine all by himself. When he wasn't producing smoke he was doing stuff like huffing butane. I'm pretty sure Rob Kabob is dead now. wstefan20 and Grandprix1 2 Quote Link to comment Share on other sites More sharing options...
vipmiller803 Posted January 22, 2018 Report Share Posted January 22, 2018 I wanted to test a moderate evap leak on the truck when I got it. I saw people on youtube who did something like what you have . I wanted something that was a little more handheld and mobile. I settled on using an e-cigarette vape combined with a battery powered fish tank aerator pump. Everything got power through a dc adapter, I want to say 5 volts. Both the pump and the vape are a little overdriven at the voltage, but they have lived through ~5 min of constant run time. I have burned baby oil in it and it does work. Sadly, that SES light in the truck is still there. I found countless leaks from dry rubber, but apparently not all. Or maybe the sensor is bad. wstefan20 and Galaxie500XL 2 Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 22, 2018 Report Share Posted January 22, 2018 Do you have any pictures of it workig? Miller I'd be curious to see what kind of plume yours generated too if you have pics. Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted January 22, 2018 Author Report Share Posted January 22, 2018 Miller, that sounds like a fun project! Someone over at gpf said they used a cigarette lighter dc plug tire pump without the regulator and it was more mobile. Only reason I like the paint can is that it uses more current and is a higher resistance than an e-cig, so it will produce a lot more smoke, and the pump will output more to catch really small leaks, but I like the portability! Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 22, 2018 Report Share Posted January 22, 2018 I'm thinking about recycling an electric smog pump wstefan20 1 Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted January 23, 2018 Author Report Share Posted January 23, 2018 I'm thinking about recycling an electric smog pump That's a novel idea! Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 23, 2018 Report Share Posted January 23, 2018 That's a novel idea! I use an F-Body one to inflate air mattresses and inflatable kayaks and they move a lot of air. I'm thinking a PVC smoke chamber and pump may fit nicely into a tool box and leave enough room inside to roll up the hoses and power wires with Alligator clips to clip onto a power stud and ground. Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted January 23, 2018 Author Report Share Posted January 23, 2018 I use an F-Body one to inflate air mattresses and inflatable kayaks and they move a lot of air. I'm thinking a PVC smoke chamber and pump may fit nicely into a tool box and leave enough room inside to roll up the hoses and power wires with Alligator clips to clip onto a power stud and ground. I wouldn't do pcv personally. That stuff gives off terrible toxic fumes when it burns, and it will get hot. But yeah, you could definitely make a more portable container that is made out of metal or something. I almost got a quart sized paint can instead of the gallon. Galaxie500XL 1 Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 23, 2018 Report Share Posted January 23, 2018 What's this? some kind of filter? Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 23, 2018 Report Share Posted January 23, 2018 I wouldn't do pcv personally. That stuff gives off terrible toxic fumes when it burns, and it will get hot. But yeah, you could definitely make a more portable container that is made out of metal or something. I almost got a quart sized paint can instead of the gallon. So the can gets warm? Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted January 23, 2018 Author Report Share Posted January 23, 2018 So the can gets warm? Quite warm. Might just be the resistance I used. If you go lower the resistance, the less it'll smoke and heat up. Oh, and that's actually a ball valve. Ended up not being useful since you can't put too much back pressure on the can. Best to just use the regulator knob. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 23, 2018 Report Share Posted January 23, 2018 I'm not ready to build yet but maybe I'll use an ammo can I have here to hold the pump and smoke chamber and just use a quart can for a smoke chamber. Then I can still store the wires and hose inside the Ammo box. wstefan20 1 Quote Link to comment Share on other sites More sharing options...
vipmiller803 Posted January 23, 2018 Report Share Posted January 23, 2018 Yea output volume is obviously a concern. I think the air volume is actually my limiting factor. The smoke is very dense. Imp558, oldmangrimes and wstefan20 3 Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 23, 2018 Report Share Posted January 23, 2018 That's pretty cool. Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted January 23, 2018 Author Report Share Posted January 23, 2018 Nice! It should work just fine for most major leaks. Definitely more portable than an air compressor and a 1 gallon paint can! Quote Link to comment Share on other sites More sharing options...
Galaxie500XL Posted January 23, 2018 Report Share Posted January 23, 2018 I wouldn't do pcv personally. That stuff gives off terrible toxic fumes when it burns, and it will get hot. But yeah, you could definitely make a more portable container that is made out of metal or something. I almost got a quart sized paint can instead of the gallon. You could maybe use a bong...it's designed to handle large volumes of smoke... But that's probably a terrible idea. Imp558 1 Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted January 23, 2018 Author Report Share Posted January 23, 2018 You could maybe use a bong...it's designed to handle large volumes of smoke... But that's probably a terrible idea. Depends on what you use if for.... Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 23, 2018 Report Share Posted January 23, 2018 (edited) Just watched a video where some cat made one with a quart sized can and it smoked pretty good. I was thinking maybe a windshield washer pump (universal) would move one PSI of air or so and be small enough to make that a very portable smoker. Edit: Wait it's 1 PSI? Maybe a 12V computer fan glued to a funnel, that's like nothing. There are small pumps 2/ $8 on Amazon that do 350 mmHG which is 6.76 PSI. Edited January 23, 2018 by Imp558 Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted January 23, 2018 Author Report Share Posted January 23, 2018 I'd probably go with the small pump. I cranked the psi to 2 psi and it worked well Quote Link to comment Share on other sites More sharing options...
Imp558 Posted January 23, 2018 Report Share Posted January 23, 2018 Actually that pump would probably be pretty close anyway, it's like a 1/4" outlet. Nice that there's 2 for that price because to make 1 - 2 PSI in the chamber it may actually take both. Quote Link to comment Share on other sites More sharing options...
carkhz316 Posted February 7, 2018 Report Share Posted February 7, 2018 Excellent build and post wstefan20! A word of advice/ caution to anyone using these: if using to find leaks in the EVAP system, be extremely careful or avoid using compressed/ ambient air to check, as inducing air (oxygen) into the evap system has the potential for creating a bomb. Optimally, one should use an inert gas (CO2 or Nitrogen) if possible. wstefan20 and vipmiller803 2 Quote Link to comment Share on other sites More sharing options...
wstefan20 Posted February 7, 2018 Author Report Share Posted February 7, 2018 Excellent build and post wstefan20! A word of advice/ caution to anyone using these: if using to find leaks in the EVAP system, be extremely careful or avoid using compressed/ ambient air to check, as inducing air (oxygen) into the evap system has the potential for creating a bomb. Optimally, one should use an inert gas (CO2 or Nitrogen) if possible. Thanks!Good to know! Evap Valve should be shut when off when engine is of right? Quote Link to comment Share on other sites More sharing options...
Imp558 Posted February 7, 2018 Report Share Posted February 7, 2018 (edited) Ideally, unless it's broke. It's common to smoke the evap and gas tank looking for leaks underneath so that's probably what he was referring to. Would probably want to have a little airflow before starting the coil so gas vapors don't travel back into a burning smoker. The commercial ones use air but I get what he means about inert gas. Have to wonder if the wick would start going without air though. Edited February 7, 2018 by Imp558 Quote Link to comment Share on other sites More sharing options...
