5stevo4 Posted February 21, 2017 Report Share Posted February 21, 2017 Anyone know if DIC gauges (volts, temp, tach) are all transported by serial data line? All were reading fine up until a week ago. Now corrupted info, also lost gauge cluster digilog tach at same time. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted February 21, 2017 Report Share Posted February 21, 2017 Should be the tan wire, "serial data uart" they use it all the way to 1997 despite having the superior "class II serial data" by then. Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 21, 2017 Author Report Share Posted February 21, 2017 Thanks for responding. Mine is an orange wire. In common with ALDL port. Shown in my original shop manual and verified continuity to ALDL, ECM and 15 amp fuse with ohmeter. Quote Link to comment Share on other sites More sharing options...
rockfangd Posted February 21, 2017 Report Share Posted February 21, 2017 I thought orange was a hot constant IIRC. The tan wire is the communication line. I am going to have to look back at my diagrams to remember more. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted February 21, 2017 Report Share Posted February 21, 2017 You're both right, early uart were orange to pin "M", obdII has pin 16 as an orange battery power. Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 23, 2017 Author Report Share Posted February 23, 2017 Yes, M terminal on ALDL connector. I believe the DIC tachometer gauge data is sent via this orange line, what about the battery volts and coolant temp guages on the DIC? Also the digilog gauage cluster tach. Do all of these use the serial data line? Quote Link to comment Share on other sites More sharing options...
rockfangd Posted February 23, 2017 Report Share Posted February 23, 2017 (edited) do me a favor. Go to the FAQ section and look at the writeup I did. titled Cutlass DIS installation info I bumped it so that it would be easy to find. Should help you a bit. I also wondered if the DIS you have is original or was added later FYI the FAQ section is above the general section on the main forum page Edited February 23, 2017 by rockfangd Quote Link to comment Share on other sites More sharing options...
Imp558 Posted February 23, 2017 Report Share Posted February 23, 2017 http://www.w-body.com/topic/43490-cutlass-dis-installation-info/?do=findComment&comment=1232672 Quote Link to comment Share on other sites More sharing options...
rockfangd Posted February 23, 2017 Report Share Posted February 23, 2017 http://www.w-body.com/topic/43490-cutlass-dis-installation-info/?do=findComment&comment=1232672 no idea how you did that but thank you Quote Link to comment Share on other sites More sharing options...
Imp558 Posted February 23, 2017 Report Share Posted February 23, 2017 no idea how you did that but thank youjust cut and paste the address bar Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 24, 2017 Author Report Share Posted February 24, 2017 Thanks rockfangd & Imp 558. That pin out is not in my manual and gives me more tests to do to track down why corrupted DIC gauges volts, tach and coolant temp are not working. And lost digilog tach at same time so there must be something in common. I know its not the gauge cluster because tach does its startup display of 0-max rpm and back to 0. Your pin out also reminded me of the DIC fuel level sensor periodically alarming for low fuel level even if tank is full. Great info. BTW, I listed this car for sale here with a couple of pics if anyone is interested. Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 24, 2017 Author Report Share Posted February 24, 2017 To answer rockfangd, I believe the DIC is original but I have only owned the car for about 7 years. I could attach a pic of interior if I could find the attachment link Quote Link to comment Share on other sites More sharing options...
rockfangd Posted February 24, 2017 Report Share Posted February 24, 2017 Do you have the UB3 digital cluster? To date that was the coolest instrument cluster I have ever seen. I loved that and my HUD. Ingenious I say Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 24, 2017 Author Report Share Posted February 24, 2017 yeah, and everything was working great until about 3 weeks ago when I lost gauge cluster tach and DIC gauges. The car is listed in the for sale section if you want to see it. Cant figure out how to attach pics to these posts. links above this type dont seem to work. Would like to attach 4 pics of interior Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 24, 2017 Author Report Share Posted February 24, 2017 This is the Craigslist ad. https://jacksonville.craigslist.org/cto/5999031630.html Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 24, 2017 Author Report Share Posted February 24, 2017 Put pic of UB3 display on CL ad listed in previous post Quote Link to comment Share on other sites More sharing options...
rockfangd Posted February 25, 2017 Report Share Posted February 25, 2017 that cd player is ultra rare also. I have onle ever had one and it worked. That is very early for the generation Quote Link to comment Share on other sites More sharing options...
jiggity76 Posted February 25, 2017 Report Share Posted February 25, 2017 I was wondering about the CD player. Was 1989 the first year Oldsmobile offered it in the Cutlass? Quote Link to comment Share on other sites More sharing options...
rockfangd Posted February 25, 2017 Report Share Posted February 25, 2017 Do believe so. Nice unit Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 25, 2017 Author Report Share Posted February 25, 2017 Unfortunately, CD doesn't play. Been planning to open it up to see about fixing it. Used to do that for a living. Also, its not original. Got it from another Cutlass at junkyard. Original was a cassette player. Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 25, 2017 Author Report Share Posted February 25, 2017 The picture of the UB3 display shows the moment when the key is turned on and it is doing its initial diagnostic test. You can see that the tach is displaying max rpm. Right after I took the picture it went back to zero. This tells me that the gauge cluster is ok and that the reason the tach is not working is because its not receiving rpm data. What say you? Quote Link to comment Share on other sites More sharing options...
5stevo4 Posted February 25, 2017 Author Report Share Posted February 25, 2017 Also notice the climate control system is not displaying. after a couple of minutes it will come on slowly, on/off on/off on/off then stay on. Took unit apart and did some soldering but didn't help. May go back in and do ic pins. Quote Link to comment Share on other sites More sharing options...
RobertISaar Posted February 25, 2017 Report Share Posted February 25, 2017 if it's display oddities only, you may have to replace the caps for the high voltage supply used to drive the VFD. Quote Link to comment Share on other sites More sharing options...
Nas Escobar Posted February 25, 2017 Report Share Posted February 25, 2017 I was wondering about the CD player. Was 1989 the first year Oldsmobile offered it in the Cutlass? I think CD player didn't become an option until the 90's. Quote Link to comment Share on other sites More sharing options...
Padgett Posted February 25, 2017 Report Share Posted February 25, 2017 (edited) My 1990 Bonneville had a CD, 90 Reatta has both CD and cassette. Believe Caddy had one as part of a Bose radio option in '89. Edited February 25, 2017 by Padgett Quote Link to comment Share on other sites More sharing options...
