Dark Ride Posted March 24, 2018 Author Report Share Posted March 24, 2018 The new switch is aftermarket unfortunately, I couldn't find any new acdelco ones. The cam is definitely busted, some of the emitters are broken off. Guessing someone screwed it up last time they replaced the signal switch. A nearby junkyard may have a steering column with srwc, would any 89-93 column work as long as it has swrc? Would the later years be better as they improved the design? jman093 1 Quote Link to comment Share on other sites More sharing options...
jman093 Posted March 24, 2018 Report Share Posted March 24, 2018 The new switch is aftermarket unfortunately, I couldn't find any new acdelco ones. The cam is definitely busted, some of the emitters are broken off. Guessing someone screwed it up last time they replaced the signal switch. A nearby junkyard may have a steering column with srwc, would any 89-93 column work as long as it has swrc? Would the later years be better as they improved the design? I would think any 89-93 SWRC would have it. 94+ won’t work. It uses a clockspring. Quote Link to comment Share on other sites More sharing options...
Dark Ride Posted March 24, 2018 Author Report Share Posted March 24, 2018 Ok I'll see if I can find an 89 - 93. Quote Link to comment Share on other sites More sharing options...
Dark Ride Posted March 28, 2018 Author Report Share Posted March 28, 2018 Got one from a 93. The rings on the back side are really dirty though, what kind of grease do they use on these? Planning to clean the old stuff off since it's so nasty. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted March 28, 2018 Report Share Posted March 28, 2018 I use white lithium for that stuff (Vaseline) Quote Link to comment Share on other sites More sharing options...
Dark Ride Posted May 26, 2018 Author Report Share Posted May 26, 2018 Finally got this installed and put back together. I hooked up the tool I bought to perform the tests and the brand new turn signal failed one of the tests, nothing where battery voltage should be. So I basically gave up on getting them to work and finished reassembling it anyway. Put it all back together and figured I would try to program it one last time before removing it and it worked! I was able to completely program everything and the steering wheel controls now control the deck. Not sure how but I'm not complaining. One weird issue I noticed after I put it back together though. The blinkers work as intended unless I turn the headlights on, then they won't flash, just solid. Any idea what would cause that or where I should look? Quote Link to comment Share on other sites More sharing options...
Nas Escobar Posted May 29, 2018 Report Share Posted May 29, 2018 Check the brake lights and marker lights with them on. You might have a bulb out that wont flash the 2nd filament. Quote Link to comment Share on other sites More sharing options...
Dark Ride Posted December 8, 2018 Author Report Share Posted December 8, 2018 Finally got this fixed. It was a bad flasher. Seems obvious in hindsight. pwmin 1 Quote Link to comment Share on other sites More sharing options...
Nick727 Posted May 2 Report Share Posted May 2 can someone post a link(s) or part #'s or the exact type for SWC adapter for my 93 cutlass. I'm having no luck finding one. Thanks Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted May 9 Report Share Posted May 9 (edited) I know I have one NOS in my my Parts Stash, and theres another member wanting to buy some parts out of that box... I just gotta find it in my garage.. Kids... Dont hoard stuff.. When you want something, you will NEVER find it! Edited May 9 by Pontiac6KSTEAWD jiggity76, pwmin and Nick727 2 1 Quote Link to comment Share on other sites More sharing options...
Nick727 Posted May 10 Report Share Posted May 10 14 hours ago, Pontiac6KSTEAWD said: I know I have one NOS in my my Parts Stash, and theres another member wanting to buy some parts out of that box... I just gotta find it in my garage.. Kids... Dont hoard stuff.. When you want something, you will NEVER find it! That would be amazing!! Please keep me posted. Quote Link to comment Share on other sites More sharing options...
