92Lumi reacted to a post in a topic: Starting the hunt for a 91 Grand Prix GTP
Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
