  2. White93z34
    Here's a picture from back when the black car was in better days.
  3. Yesterday
  4. jiggity76
  5. jiggity76
    Cloth.
  6. rcLord510
    that cloth or leather?
  7. rcLord510
    i was gonna whip this out but 94 olds beat me to it
  8. White93z34
    I'll have to find some pictures. Best ones I have are from 10+ years ago when the black one was in far better shape. Long story short, engine blew up, it sat outside. Then I ended up with it and moved it to indoor storage but the time outside had already taken its toll. Right now its very dusty and sad looking and buried in the back of storage so its hard to even see it right now. Last couple weeks I've been daily driving my red one. Made me realize how much I've missed the turbo cars. I think technically speaking red/gray was the most rare color combo. If you'd have asked me years ago I'd have been on board with the gray interior all day long. Now I think the tan works with the gold wheels and badging. I'm torn because the chassis of the black car IS that much better. But I've put insane amounts of work into making the red one as good as it presently is. Not sure if rarity of the color combos really moves me like it would used to. Maybe I can use that to my advantage to get more money out of the black one. Some guy on FB wanted to buy both but wanted to pay a very small sum for them. I dono I think they tend to wear arrest me red better then black. I think whatever happens the sale of one and a bunch of parts will fund the restore of the other. I'm still very much torn as the black one when it was running really drove fantastically. I'm just rambling at this point.
  9. jiggity76
    With his Black car, I've only seen 4 with Gray interior. One of the 4 was a red car. This is 1 of the 4 gray interior cars. It was about an hour South of me at a private yard. It still might be there. Makes me incredibly sad.
  10. pwmin
    If you like the red, keep the red one. It will be easier. I would go the torturous route because I would want the black/gray cloth one. That is what I want if I can find one. Or maybe the red one and swap to the gray cloth.
  11. jiggity76
    For me, definitely the Black one. It being Black...and having Medium Slate Gray cloth, that is uber rare in the TGP World. You know me, rarity is a big deal and that one is definitely incredibly rare and sought after. I firmly believe that even though it's not in the better shape, you'll regret selling it later.
  12. 94 olds vert
    My opinion would be to keep the car that is running and driving and start to do the body and paint work on it. I'm not sure how bad the exterior on the red TGP is. Body work can get expensive. I guess I would need some pictures of the red TGP.
  13. White93z34
    So as some of you know I've recently pulled my red 90' TGP from its 9 years long slumber. I've been enjoying it quite a bit. Which has made me rethink selling all my TGP stuff... for the time being. However... I don't think I need 2 of these damn things. So help me decide which stays and which goes. Red 1990 TGP: Pros: Red/Tan leather/Sunroof/CD player 151,000 Miles Has the engine from my old wrecked TGP in it so approximately 40-50,000 fewer miles than the chassis, Runs great. recently rebuilt transmission Presently Running and driving Vacuum Brake converted Have brand new Turbo/Pontiac emblems in a box for it Body is pretty clean rust wise, no immediate concerns Rear subframe converted to 2g lat links 96' Front and rear brakes Cons: Needs a paint job Been in a few accidents, repaired... not the best. Could really use an entire Driver side B pillar replacement (have most of those parts) but is passable enough as is. Only original body panels are the pass door and fender. literally every other part has been replaced for one reason or another Black 1990 TGP: Pros: Black/Gray cloth/Tape deck I think 110,000 or someplace about there miles body is straight as an arrow Used to be owned by @LukeZ34so it has forum history 94' rear brakes Have a supposedly good engine on a stand for it. Cons: Also could use a paint job, not as bad but not good either Been off the road since about 2011, presently stored indoors Needs an engine - It ran but had very minimal oil pressure. Will need the fuel system totally flushed before it gets running. Still has PowerMaster brakes - worked last time it ran but it needs to go regardless. Obviously the black car is the better base on paper. But my irrational part loves how they look in red. Whats you guys take?
  14. Last week
  15. I just figured it out! Got the GXP brackets and calipers from NAPA. They cut the mounting part off and drilled/tapped new mounting holes.
  16. GnatGoSplat
    Luminac
    I so very much hate these cross-era mashup cars, but my retinas are burned so I thought I'd share. https://www.junkyardlife.com/2015/11/luminac-repurposed-1958-cadillac-fins.html
  17. I tried SSR ones. I think they're the same as the Trailblazer, but I'm not sure. It was the closest yet, but still not correct. Both of the holes on this bracket are 8 1/4 center to center. They're directly in line and the front brace is straight across. Not that that part really matters. I'm going to look at the Cardone catalog and see what I can find. I can ask them as well. Last resort I might take them off and see if NAPA can match them up. I did have my dad order GXP calipers with brackets from NAPA to his shop that I'm going to check out today, but I'm not very hopeful. Figured I'd give it a shot.
  18. Reminds me of the caliper brackets on my Trailblazer. There's two kinds at the front, which has two-piston calipers. The calipers are the same, but the brackets are different between the regular-wheelbase Trailblazer (GMC Envoy, with Saab and Isuzu versions also.) and the extended-wheelbase Trailblazer and clones. The extended-wheelbase vehicles got slightly larger rotors, so the bolt spacing on the brackets is a little different.
  19. 55trucker
  20. GnatGoSplat
  21. Black92GS
  22. GnatGoSplat
  23. Black92GS
  24. GnatGoSplat
  25. rcLord510
  26. kielu84
    2001 Buick Regal Intermittent No Start
  27. The search continues. Does not look like it will work to me. I'll follow up on any leads I can get.
  28. GnatGoSplat
