Turbocharged3800 reacted to a post in a topic: COOLANT LEVEL SENSOR DISCONTINUED FOR 2.8L V-6 & 3.1L W-body cars
Turbocharged3800 changed their profile photo
I’ve driven a gen 1 with FE3, my gtp, a 05 monte ss, so I haven’t drive a 3rd gen, but I will say the 2nd gens are much nicer driving. I like the cs but the gtp handles better in a lot of ways, but it depends what you consider better handling. For better cornering, the cs wins, for traction, and squat when accelerating, my gtp wins in that. So I guess it largely all depends. - Earlier
? how short are you?.....
