Hmm I am not positive but that does seem to make sense given when its happening. Im not necessarily on the brakes when it happens, but sometimes just letting off the accelerator causes it. I have an Autel scanner. Would there be a way for me to watch for this using live data in some way? -
Ok. Now this may sound like a really weird question....are you absolutely positive that the ABS isn't activating when you're slowing down? The ABS pump activates briefly during its self check shortly after startup (or when you first start moving...can't recall which). In every 90s/2000s GM i've driven, including a 2000 Regal, the ABS pump initially kicking in would often cause a bit of a power dip (headlights dimming slightly, blower speed audibly slowing slightly etc..). Something that I have also had issues with in some of those vehicles has been unwanted ABS activation from weak/failing wheel speed sensors and/or failing tone rings. You may need to really listen and feel for an unwanted ABS activation, as it can range from being a very quick and random engagement of the pump that you don't really feel.... to full on constant ABS activation with the pushback of the pedal and the sensation of a loss of braking power. -
1995 Monte Carlo No Heat
The latter would be a better description. It’s like a large draw and they will dim then go back to normal. Sometimes it does it once’s, sometimes a few times in a row -
You'll have to define the pulsing. Is it like a continuous flicker, or is it more along the lines of a large draw where the lights briefly dim once and then come back up? -
mikeytcarter started following 2002 Buick regal intermittent headlight pulsing
Hello everyone! i have recently acquired a 2002 Buick Regal. This car was a one owner car and I picked it up in October with 74k miles on it. It has been very well taken care of. I bought this car because of the reliability factor, however I have fallen in love with how it drives! The only issue that I am having is intermittent headlight pulsing. It only happens when the car is decelerating and slowing down under 30mph or so. So far I have replaced the battery, had the alternator tested(tested good ), went and bought another alternator and installed just in case of possible voltage regulator. Also found and cleaned thee grounds under the fuse box, next to the drivers headlight, and the engine ground by the exhaust. I have also ran a big 3 wire upgrade (did this for future sound system) as well as an extra power wire from fuse box to alternator(saw some videos where people said this extra line helped)This seemed to make my headlights a bit brighter, but not affect on the pulsing. All that being said i am still getting the same result. The interior lights will dim for a moment when the car first starts and the the headlights on deceleration. From what I have found there is no headlight relay, only fuses. I have one friend who has suggested new bulbs, however I am not convinced this would fix anything as they are older but still light up well. Any suggestions on where to look next would be greatly appreciated!
mikeytcarter joined the community - Last week
I would use an older PCM from a different 3800, which is what every swap guide I read suggested in the first place. I used the engine-matching PCM because it ended up being easier, but there must be reasons previous swappers used late 90's PCMs instead. I also have an 2000 GTP and 98 Lumina LTZ PCM. Both of them tested to start and run the engine, but both had different transmissions and the LTZ is N/A. Both would need programming, but one of them might have a compatible switched ground AC request signal. Surely I'm not the first person to have AC in their L67 swap!?
Taking a good look at the potential V5 contenders, it's apparent that you are going to be limited to a V5 from only the 3.8 engine family. Attempting to use a V5 *134a* from a '96 60 degree engine will not clock properly & the housing castings are different & not compatible with the 90 degree engines. This means you can't use an ODB1 V5 compressor at all. Since you're stuck with a 134a compressor you have to use the 134a hose manifold assembly which will not fasten to your existing receiver/dryer unless you go to the effort of cutting off the pipe ends & swapping them & tigging the old fittings to the new manifold. The same B.S I went thru.......... if one doesn't go the *custom* route you have to change both the receiver/dryer & the liquid & gas line into & out of the evaporator core.
