  2. Quaraxkad
    L67 swap A/C
  3. Today
  4. Black92GS
    L67 swap A/C
  5. pwmin
    1995 Monte Carlo No Heat
  6. 55trucker
    L67 swap A/C
  7. Bake82
    L67 swap A/C
  8. bluecalais79
  9. Quaraxkad
    L67 swap A/C
  10. Yesterday
  11. pwmin
  12. Black92GS
  13. bluecalais79
  14. Last week
  15. primergray
    Sitting 1995 Regal GS
  16. Black92GS
  17. Amanita
  18. 55trucker
  19. bluecalais79
  20. 55trucker
  21. bluecalais79
  22. pwmin
  23. ron350
  24. pwmin
  25. ron350
  26. 55trucker
  27. pwmin
  28. Earlier
  29. 55trucker
    Well, defrost is the default direction for all optional failures, as for the heat can you get your hands around the inlet or outlet core piping to feel what the coolant temp is? if the blend door is stuck closed so the inlet air bypasses the core that would deliver what you're presently getting. One can see the actuators if you pull off the instrument panel cover, they are right behind where the glove box is.
  30. pwmin
