  2. GnatGoSplat
  3. Today
  4. rcLord510
  5. rcLord510
  6. rcLord510
    Anyway to fit 6.5 speakers in my 5.25 speaker bracket
    i may be wrong, since thats a 1.5 gen, but on the 2nd gp its a plastic ring that brings the speakers out closer to the door, that can be removed and i have personally test fit 3 different 6.5 drivers that will fit with the window, as thats gonna be your biggest issue, so it definetly depends on magnet size with the driver, but i know on gp's a few different drivers will fit. if youre gonna be using a 2 way system, youll have to cut a hole for the tweater or make a pod for it up on the a-pillar
  7. Could be. I will look into it. I bought an SSR bracket and it's not correct, either. It's in between the 2 GMT800 ones. GMT900 won't work either.
  8. Turbocharged3800
    Mystery Caliper Bracket
    I swear that looks like a ferd pbr caliper bracket from the mustangs.
  9. Last week
  10. GnatGoSplat
  11. Any idea what these could be from? Custom strut housings for my Monte to fit GXP brakes, but the caliper bracket is not from a GXP and I have no information on it. Tim sent me everything he had, but it's not in there. No clue who made these strut housings back in the day. The Chevy dealer crossed it to a GXP bracket, but the bolt holes are about 8 1/4" apart instead of 5-ish for 2G W-bodies. Small GMT800 brackets are too small but the larger ones are too big. I have one on order from an SSR, which should be in between sizes, but I'm not sure. It's a different Cardone number from either of the GMT800 ones, so hopefully it's different. It doesn't look the same, but as long as the holes line up. Last picture is of GXP caliper and bracket.
  12. Earlier
  13. I’ve driven a gen 1 with FE3, my gtp, a 05 monte ss, so I haven’t drive a 3rd gen, but I will say the 2nd gens are much nicer driving. I like the cs but the gtp handles better in a lot of ways, but it depends what you consider better handling. For better cornering, the cs wins, for traction, and squat when accelerating, my gtp wins in that. So I guess it largely all depends.
  14. I think youd have to do it by generation, as there are some significant changes by generation as well as intent (when you get to the later years there was more of a focus on handling handling vs the earlier focus on comfort handling). In addition, its important to consider that skidpad Gs do not equal handling. Ive driven race cars that would do an epic skidpad number but are so ill handling in transition/under braking/whatever, that they are virtually undriveable. I have the most experience with 1st gen w-bodies, and my vote there would be for the FE3 level Grand Prix coupe with the 245 wide tires. Though I suspect/wonder if the 1990 olds international with FE3 and the quad 4 would be the ultimate iteration for handling. Ive never driven one (almost nobody has) so I cant say definitively, hence my mention above of the 245 tire equipped GP. For gen 1.5, Im not sure. For the last generation, its most likely the 2008 GP GXP. The fact they fitted reverse stagger tires (and engineered the suspension to utilize this setup) tells me someone understood how to make an FWD car handle.
  15. 94 olds vert
    Best handling factory w body?
  16. Just wondering which factory w body was the best handler. My initial thought was the 04 grand prix gtp comp g which had a 0.81g skidpad rating. however after doing some more research I found that the 2002 oldsmobile intrigue GLS had a 0.84g skidpad rating just wondering from those who have owned many w bodies which one handled the best
  17. 89-W-Body-Regal
    Does anyone live near there? I need your help!
  18. Black92GS
  19. rich_e777
  20. rich_e777
  21. Black92GS
  22. Schurkey
  23. Schurkey
  24. rcLord510
  25. 55trucker
  26. rcLord510
  27. 55trucker
    ? how short are you?.....
  28. rich_e777
  29. crazyd
    Intermittent A/C!
