Raffaelli reacted to a post in a topic: 2nd Gen Rear Brakes on a 1/1.5 Gen
92Lumi reacted to a post in a topic: Total dash swap 92 Lumina, what will fit?
Found another video. My strut tower looks nothing like this down the hole. Look at all the clearance he has for the tool. Now I know my top mount was replaced because the cartridge on my strut mount gets stuck under the mount if you use the strut rod to compress it down into the tower. Is it possible someone who worked on my 89 regal the first time removed the whole strut and replaced the top mount? I cannot find any aftermarket mount for my Buick anywhere online for these struts. It all says to replace the cartridge with that tool kit. Is it possible to replace the top mount back with oem from the factory if I can find the mount? - Yesterday
94 olds vert reacted to a post in a topic: 2nd Gen Rear Brakes on a 1/1.5 Gen
Ok so I wanted to let everyone know in here I had no luck still replacing the front strut cartridges with the tool kit I got off eBay to replace these strut cartridges. My friend came over to help me work on my Regal to replace the strut cartridges. We found out the strut cartridges have been played around with the first time they were replaced before. Someone who worked on it years ago tried cutting the top strut tower because we found small cut marks along where the studs are for the strut tower mount. We also found out they replaced the top mount with an aftermarket mount. So that’s why the strut tower will not fit the spanner nut extension down into the tower to loosen the cartridge nut. We have to remove the whole strut and compress it to remove the cartridge. What a pain in the ass. - Last week
1990 cutlass international
