  2. Black92GS
    L67 swap A/C
  3. Today
  4. Quaraxkad
    L67 swap A/C
  5. Black92GS
    L67 swap A/C
  6. pwmin
    1995 Monte Carlo No Heat
  7. 55trucker
    L67 swap A/C
  8. Bake82
    L67 swap A/C
  9. bluecalais79
  10. Quaraxkad
    L67 swap A/C
  11. Yesterday
  12. pwmin
  13. Black92GS
  14. bluecalais79
  15. Last week
  16. primergray
    Sitting 1995 Regal GS
  17. Black92GS
  18. Amanita
  19. 55trucker
  20. bluecalais79
  21. 55trucker
  22. bluecalais79
  23. pwmin
  24. ron350
  25. pwmin
  26. ron350
  27. Earlier
  28. 55trucker
  29. pwmin
  30. 55trucker
    Well, defrost is the default direction for all optional failures, as for the heat can you get your hands around the inlet or outlet core piping to feel what the coolant temp is? if the blend door is stuck closed so the inlet air bypasses the core that would deliver what you're presently getting. One can see the actuators if you pull off the instrument panel cover, they are right behind where the glove box is.
