rcLord510 started following Best handling factory w body?
I've driven a decent amount of W-body cars over the years. I really like my 2000 GTP compared to the 1st gens that I've owned. I've only driven a base model 3rd gen so I'm sure that isn't a fair comparison. I've never owned a 3rd gen GP. But I guess a GXP is always on the list. Not sure what the best handling one is I can only go with what I've driven and what cars I've owned over the years. - Earlier
? how short are you?.....
