  2. White93z34
  3. Today
  4. The threads on the fitting for my EGR tube at the exhaust manifold no longer exist. The tube isn't available anywhere. Figured at this point I'd just delete the EGR. Are there any ways to trick the car into thinking there's still an EGR so I don't have annoying check engine light? 1994 Pontiac Grand Prix 3100
  5. Yesterday
  6. Black92GS
    1st Gen W body 14" wheels?
  7. 55trucker
  8. Black92GS
  9. White93z34
  10. 55trucker
  11. Last week
  12. Mach 5
    TGPForums.com Future
  13. Earlier
  14. I talked to the original owner Kevin a year after buying the car and he showed me old photos of it in Florida before it came up to ohio, guy definitely loved this car. Shame it's poptart crust now.
  15. Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
  16. carkhz316
  17. GnatGoSplat
  18. GnatGoSplat
    LED 3rd brake light write up
  19. GnatGoSplat
  20. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  21. cutlassman
  22. Raffaelli
  23. jiggity76
  24. rich_e777
  25. Did it make it to 200k?
  26. Black92GS
    OIL LEAK - 1994 Cutlass LQ1
  27. White93z34
  28. Black92GS
  29. bluecalais79
  30. White93z34
