  2. Got the knuckles swapped over and the GXP brakes installed. Going to tackle the e-brake next. Going with a rip-it style handle from an 04-ish J-body and a center console from an 00+ Monte. I have new rear e-brake cables from a 2G, so I'm going to need to figure out how to mate them with the Cavalier one. I know there's a thread somewhere on going to this style e-brake, but I can't find it. Anyone know where it is?
  3. be careful with the springs. they are huge and under more tension then i've seen on most others. Nearly killed myself when one went orbital on me. That said if you're going that far its perhaps worth your while to get some 96' knuckles so you can run the larger rotor
  4. Ok so I wanted to let everyone know in here I had no luck still replacing the front strut cartridges with the tool kit I got off eBay to replace these strut cartridges. My friend came over to help me work on my Regal to replace the strut cartridges. We found out the strut cartridges have been played around with the first time they were replaced before. Someone who worked on it years ago tried cutting the top strut tower because we found small cut marks along where the studs are for the strut tower mount. We also found out they replaced the top mount with an aftermarket mount. So that’s why the strut tower will not fit the spanner nut extension down into the tower to loosen the cartridge nut. We have to remove the whole strut and compress it to remove the cartridge. What a pain in the ass.
  5. Last week
  6. Been a long time since I've played with rear brakes on a '92 or '93 W-body, but I don't remember there being an access problem.
  7. anyone on here who has a passenger side door for the two door cutlass-preferably black. hit me up i am interested in buying if you are interested in money
  8. Human
  9. jiggity76
  10. So, Wednesday marked seven years to the day that I took delivery of my '95 Cutlass Supreme convertible, which also means the registration is due for renewal. When I took it in for that today, I was informed that since the car is now 30 years old, the state of North Carolina considers it to be "vintage vehicle," and such it no longer requires an annual state safety inspection. Fine by me, that's a few dollars I didn't have to spend today. I also believe the Antique Automobile Club of America would consider it an antique.
  11. Earlier
  12. Black92GS
    Intermittent A/C!
  13. crazyd
    Intermittent A/C!
  14. Black92GS
    Intermittent A/C!
  15. crazyd
    Intermittent A/C!
  16. Black92GS
    Intermittent A/C!
  17. crazyd
    Intermittent A/C!
  18. 55trucker
  19. cutlassman
  20. 55trucker
  21. cutlassman
  22. 55trucker
  23. Hey everyone, my 1992 Cutlass Supreme Convertible I’ve had since 2000 is dead. It hydrolocked. I did manage to get it to start a couple times for a few seconds, but there’s a horrible knock and coolant out of the dual exhaust. I’ve ripped it down to the block once, about 14 years ago and don’t feel like doing it again. I should junk the car…but you know how that goes. So, I’m looking for a remanufactured engine with a warranty that I’ll have a local shop install. Any recommendations on the best company to go with? Looking at S&K Engines….Accurate Engines…ATK via Jegs…let me know if you have any experience with a remanufactured engine, or a shop in the Southeast I could send it to.
  24. Black92GS
    Intermittent A/C!
  25. crazyd
    Intermittent A/C!
  26. I don't recall the space being restricted, but might have to get a breaker bar on there and a BFH (Big F-ing Hammer).
  27. DIY coilovers. There's no other readily available way.
  28. Black92GS
    Intermittent A/C!
