  1. Yesterday
  2. rcLord510
    TGPForums.com Future
  3. LukeZ34
  4. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
    Now in that same spot I see a coolant leak . Very small but it's there. I will be trying out some bar-seal stop leak on it in the hope this will stop it. Old car, you gotta love 'em. Or hate 'em, I don't know which. Something else that's odd is, I had them change out the LOW COOLANT sensor for a new one, and the LOW COOLANT warning still went on anyway. The car is not low on coolant. Geez.
  5. The booster is held on with a 1/4 turn lock. Make sure the locking tab isn’t holding it from rotating, (push/pull it into unlocked position.) then get a prybar on the master cylinder studs and rotate it off. It’s so simple it’s stupid. Just an odd ball design.
  6. My father owns a 94 cutlass supreme convertible and its brake booster has failed. Everywhere i look for steps to replace the booster mentions 4 bolts holding the booster from inside the firewall, however, when I go to look, no bolts are to be found. When I look at the new booster, it seems to lock into place using grooves and some kind of locking bar. Nothing I do really does anything to get this booster to move and I am stumped on how to progress. The coter pin is out and the pedal disconnected. The master cylinder and abs contraption is off and out of the way. Theoretically, it should pop right out, yet it holds firm. Any help would be greatly appreciated! Thank you in advance.
  7. Last week
  8. Hey everyone, im currently looking for a couple of trim pieces for my 2002 buick regal. Im looking at getting the passenger door trim molding (exterior) and the rear deck seat belt cover (pic attached) willing to buy a whole door if need be
  9. GnatGoSplat
    Rust free rotors?
  10. 94 olds vert
    Rust free rotors?
  11. rich_e777
    Rust free rotors?
  12. Earlier
  13. Jscott
    Sunroof help again.
  14. Black92GS
  15. bluecalais79
  16. cutlassman
  17. bluecalais79
  18. GnatGoSplat
    Rust free rotors?
  19. GnatGoSplat
    Wiring Differences 88-90?
  20. Dude.... I own this car now.... Mine is exactly how your describing yours... From florida originally but Ohio car, hail damage, salvage title, center line wheels and the black hood and spoiler... Bro I have your car lol.
  21. Last American Indian
    Best handling factory w body?
  22. SuperBuick
  23. bluecalais79
  24. jiggity76
    How to clean my Cutlass.
  25. rich_e777
    Rust free rotors?
  26. Black92GS
    TOM ( SUPERBUICK)
  27. GnatGoSplat
    TOM ( SUPERBUICK)
  28. SuperBuick
    TOM ( SUPERBUICK)
