  1. Yesterday
  2. Last week
  3. Been a long time since I've played with rear brakes on a '92 or '93 W-body, but I don't remember there being an access problem.
  4. anyone on here who has a passenger side door for the two door cutlass-preferably black. hit me up i am interested in buying if you are interested in money
  5. Human
  6. jiggity76
  7. So, Wednesday marked seven years to the day that I took delivery of my '95 Cutlass Supreme convertible, which also means the registration is due for renewal. When I took it in for that today, I was informed that since the car is now 30 years old, the state of North Carolina considers it to be "vintage vehicle," and such it no longer requires an annual state safety inspection. Fine by me, that's a few dollars I didn't have to spend today. I also believe the Antique Automobile Club of America would consider it an antique.
  8. Earlier
  9. Black92GS
    Intermittent A/C!
  10. crazyd
    Intermittent A/C!
  11. Black92GS
    Intermittent A/C!
  12. crazyd
    Intermittent A/C!
  13. Black92GS
    Intermittent A/C!
  14. crazyd
    Intermittent A/C!
  15. 55trucker
  16. cutlassman
  17. 55trucker
  18. cutlassman
  19. 55trucker
  20. Hey everyone, my 1992 Cutlass Supreme Convertible I’ve had since 2000 is dead. It hydrolocked. I did manage to get it to start a couple times for a few seconds, but there’s a horrible knock and coolant out of the dual exhaust. I’ve ripped it down to the block once, about 14 years ago and don’t feel like doing it again. I should junk the car…but you know how that goes. So, I’m looking for a remanufactured engine with a warranty that I’ll have a local shop install. Any recommendations on the best company to go with? Looking at S&K Engines….Accurate Engines…ATK via Jegs…let me know if you have any experience with a remanufactured engine, or a shop in the Southeast I could send it to.
  21. Black92GS
    Intermittent A/C!
  22. crazyd
    Intermittent A/C!
  23. I don't recall the space being restricted, but might have to get a breaker bar on there and a BFH (Big F-ing Hammer).
  24. DIY coilovers. There's no other readily available way.
  25. Black92GS
    Intermittent A/C!
  26. crazyd
    Intermittent A/C!
  27. Black92GS
    Intermittent A/C!
  28. crazyd
    Intermittent A/C!
