If you can recall, did that rubber NOS piece have that molded dip in it or is the rubber pliable enough to make those curves? I`m looking to replace this on 3 cars and it looks like the same between 1st gen W sedans and coupes/verts. - Last week
Did it make it to 200k? -
Rust free rotors?
Rust free rotors?
