Amanita reacted to a post in a topic:
What you see is actually *6PY* ....goes with *7PY* possibly front suspension FLH *6PY, FRH *7PY* 6PY 4 2 0 3 7 P FLH M COMPONENT FRT LH COMPUTER SEL SUSP (6PY) 8 9 0 2 0 1 E 1 E A 7PY 4 3 3 3 3 P FRH M COMPONENT FRT RH COMPUTER SEL SUSP (7PY) 8 9 0 2 0 1 E 1 E A - Last week
amended -
55trucker started following Firmest front springs for a first gen?
Burg91 joined the community -
I would`ve liked that badge to be illuminated on the door pillar with black powdercoated door handles/lockplate vs the vertical pillar handle design we got.
