L67 swap A/C
55trucker started following 1995 Monte Carlo No Heat and Rear Speaker Change- 1994 Cutlass 2 Door
Well, defrost is the default direction for all optional failures, as for the heat can you get your hands around the inlet or outlet core piping to feel what the coolant temp is? if the blend door is stuck closed so the inlet air bypasses the core that would deliver what you're presently getting. One can see the actuators if you pull off the instrument panel cover, they are right behind where the glove box is.
