  2. Very cool and very worth preserving and treating right. Its rare and in beautiful condition. Thank you for treating it right.
  3. Today
  4. What you see is actually *6PY* ....goes with *7PY* possibly front suspension FLH *6PY, FRH *7PY* 6PY 4 2 0 3 7 P FLH M COMPONENT FRT LH COMPUTER SEL SUSP (6PY) 8 9 0 2 0 1 E 1 E A 7PY 4 3 3 3 3 P FRH M COMPONENT FRT RH COMPUTER SEL SUSP (7PY) 8 9 0 2 0 1 E 1 E A
  5. Yesterday
  6. Going by the RPO sticker, the fronts a little confusing. I’m assuming BPY code for the front springs
  7. This is pretty cool, I'll have to check which mine have later.
  8. amended
  9. That's a file local to your computer, we can't access it
  10. W body spring codes *paste this into your web browser address bar* my fronts are FYB, the rear is RFK *let's try this again.......this should work*
  11. Automatic equipped FE3 springs from a 3.4 DOHC car seem to be the stiffest. The manual trans springs are slightly less stiff (as compared side by side, and they have different part numbers). In other words your automatic Z34 has the stiffest ever available factory.
  12. I should have specified contacting a spring shop that specializes in making custom coil springs like this website https://www.coilsprings.com/classic-car-coil-springs No idea what numbers you'd have to give them, I wish I had a spec sheet from a discontinued aftermarket performance option for reference but I imagine those are very hard to come by.
  13. 55trucker
  14. 94 olds vert
    I know it's been done before. I think the biggest issue is always switching the vehicle over to OBDII. But if you aren't going for a Series II L67 a Series I L67 from a Bonneville that is OBD 1.5 might make a better option.
  15. Hello everyone out there. Unfortunately Gm has made the decision to discontinue the cam belt tensioner for the 3.4 dohc engine. What's the feasibility of swapping out the 3.4 with the 3.8sc?
  16. Spring shops can only install what's available in the aftermarket, & FE3's are not one of them. The springs availability is *generalized*, only the basic spring would be available.
  17. I did a bit of digging on this a while ago and unfortunately if you want to change anything about the suspension rate in these cars now past what FE3 gives you'll either need to contact a spring shop or figure out how to fit coilovers on the car. There were custom coilover mounts available here but the last batch sold out years ago. I'm sure there are springs out there that fit the car and provide a stiffer rate than stock but as far as I'm aware nobody has come across ones that fit.
  18. I gotcha. Just was wondering if there was something beefier for the W-Body I should look for.
  19. The springs are not a *Chevy* thing....all 1st Gen W's with the FE3 got the stiffest coils available. What's under your Z34 is also under a GP with the FE3 suspension.
  20. Not lower. Just have the best/highest spring rating chevy offered.
  21. There are no longer aftermarket *performance* springs manufactured for the 1st gen W's, if you've got the FE3 suspension under the car then you've already got the stiffest springs available. I take it that you want lower the front to match the dropped rear's ride height?
  22. 1994 Lumina Z34. Already have the rear end taken care of, and I wanted to beef up the front. Anyone know of the firmest springs I can get for the front of that strut design? I think I read something a while ago about 1996 Monte Carlo 3.4 front springs would be it. Suggestions?
  23. cutlassman
  24. Burg91
    03 Century 3100 - P0401 Code
  25. Last week
  26. Jscott
    Sunroof help again.
  27. Jscott
    Wiper won’t stop running
  28. Psych0matt
    Sunroof help again.
  29. rich_e777
    I would`ve liked that badge to be illuminated on the door pillar with black powdercoated door handles/lockplate vs the vertical pillar handle design we got.
