  1. Yesterday
  2. Black92GS
    1st Gen W body 14" wheels?
  3. 55trucker
  4. Black92GS
  5. White93z34
  6. 55trucker
  7. Last week
  8. Mach 5
    TGPForums.com Future
  9. I talked to the original owner Kevin a year after buying the car and he showed me old photos of it in Florida before it came up to ohio, guy definitely loved this car. Shame it's poptart crust now.
  10. Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
  11. Earlier
  12. carkhz316
  13. GnatGoSplat
  14. GnatGoSplat
    LED 3rd brake light write up
  15. GnatGoSplat
  16. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  17. cutlassman
  18. Raffaelli
  19. jiggity76
  20. rich_e777
  21. Did it make it to 200k?
  22. Black92GS
    OIL LEAK - 1994 Cutlass LQ1
  23. White93z34
  24. Black92GS
  25. bluecalais79
  26. White93z34
  27. ReiSabre
  28. GnatGoSplat
