  1. Yesterday
  2. I talked to the original owner Kevin a year after buying the car and he showed me old photos of it in Florida before it came up to ohio, guy definitely loved this car. Shame it's poptart crust now.
  3. Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
  4. Last week
  5. carkhz316
  6. GnatGoSplat
  7. GnatGoSplat
    LED 3rd brake light write up
  8. GnatGoSplat
  9. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  10. cutlassman
  11. Raffaelli
  12. jiggity76
  13. rich_e777
  14. Earlier
  15. Did it make it to 200k?
  16. Black92GS
    OIL LEAK - 1994 Cutlass LQ1
  17. White93z34
  18. Black92GS
  19. bluecalais79
  20. White93z34
  21. ReiSabre
  22. GnatGoSplat
  23. bluecalais79
  24. Picked up a 1994 Pontiac Grand Prix coupe a few months back for a good price. Im in the process of putting a new motor in it due to an oil pump failure. But I've been thinking about suspension and steering system modifications. There isn't anything available for the 1994 but there's a ton of support for 1997+. Due to differences with the control arms I figured that easiest way to retrofit would be to swap a subframe from a newer Grand Prix into my '94 but I'm not sure if that's possible. From looking up photos online The general shape and mounting position seems to be the same. I was just wondering if anyone's ever done this swap before to update the suspension and steering because I'm sure anything's better than the cartridge strip design in terms of performance.
  25. GnatGoSplat
    Sunroof help again.
  26. GnatGoSplat
  27. GnatGoSplat
    Should I go back to stock?
  28. rcLord510
    TGPForums.com Future
