  1. Last week
  2. I think I watched a guy on YouTube do one, and he used a claw hammer.
  3. Getting a pry bar on the studs is next to impossible, given the space you're working with. The service manual for the car calls for a specialty tool literally no one sells. You have to make it yourself. Hope you know how to weld. And grooves to lock it in place? Bolts not work for the engineer? Did narrow wrenches and short sockets not exist in the 90's? The idiocracy of the design choices in the W-Body is astounding! Honda out there making cheap, easy to work on commuters in the 90's while GM was living in their own little city of dreams. Hollow, dim-headed loonies, the lot of them were.
  4. 94 olds vert
  5. Psych0matt
  6. pwmin
  7. White93z34
  8. The threads on the fitting for my EGR tube at the exhaust manifold no longer exist. The tube isn't available anywhere. Figured at this point I'd just delete the EGR. Are there any ways to trick the car into thinking there's still an EGR so I don't have annoying check engine light? 1994 Pontiac Grand Prix 3100
  9. Black92GS
    1st Gen W body 14" wheels?
  10. 55trucker
  11. Black92GS
  12. White93z34
  13. 55trucker
  14. Earlier
  15. Mach 5
    TGPForums.com Future
  16. I talked to the original owner Kevin a year after buying the car and he showed me old photos of it in Florida before it came up to ohio, guy definitely loved this car. Shame it's poptart crust now.
  17. Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
  18. carkhz316
  19. GnatGoSplat
  20. GnatGoSplat
    LED 3rd brake light write up
  21. GnatGoSplat
  22. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  23. cutlassman
  24. Raffaelli
  25. jiggity76
  26. rich_e777
  27. Did it make it to 200k?
