Aceknox23 joined the community - Yesterday
laura joined the community - Last week
Coilover Spring Rates
I'm running (iirc) 450 and 350 and it's pretty dang tight, but not super stiff on normal roads (so it does suck sometimes around here haha). I'm gonna look back and see if I can find if my memory is correct edit: close, 400 and 350
