Wheel fit
Go4DaMo reacted to a post in a topic:
Power steering whine
Coilover Spring Rates
I'm running (iirc) 450 and 350 and it's pretty dang tight, but not super stiff on normal roads (so it does suck sometimes around here haha). I'm gonna look back and see if I can find if my memory is correct edit: close, 400 and 350 -
So far, it rides better. I need stiffen them up a little because the tires scrub on bumps sometimes.
Brake upgrade completed
The Ford rotor *hat* is shorter, the overall height of the Ford rotor is only 1/4" more than that of the W rotor. The Impala rotors bolt circle is 118mm (4.6"), the W rotor is 115mm & the Ford is 114.5mm (4.5"). The Ford rotors pad surface thickness is near identical to the W rotor thickness 1.040" vs Ford 1.101". -
HELP!!! Rear leaf spring bushing came out while driving
JOHN GTPPRIX replied to mycarsucks's topic in Brakes/Suspension/Steering/Wheels/Tires
I have for 24 years used the nylon pad/blocks and have had no problem. I bought and installed the rubber pads with the 3-M adhesive after cleaning them while a new rack unit was being installed. They didn't stay in place so I bought the nylon pads which lifted the car back up to a nice stance. I did grease the ends of the leaf spring. I have zero complaints and have had the car for 27 years. I replaced them once and I bought an extra pair and should install them again. -
