  2. Today
  3. Black92GS
    Intermittent A/C!
  4. Yesterday
  5. crazyd
    Intermittent A/C!
  6. Black92GS
    Intermittent A/C!
  7. crazyd
    Intermittent A/C!
  8. Last week
  9. 55trucker
  10. cutlassman
  11. 55trucker
  12. cutlassman
  13. 55trucker
  14. Hey everyone, my 1992 Cutlass Supreme Convertible I’ve had since 2000 is dead. It hydrolocked. I did manage to get it to start a couple times for a few seconds, but there’s a horrible knock and coolant out of the dual exhaust. I’ve ripped it down to the block once, about 14 years ago and don’t feel like doing it again. I should junk the car…but you know how that goes. So, I’m looking for a remanufactured engine with a warranty that I’ll have a local shop install. Any recommendations on the best company to go with? Looking at S&K Engines….Accurate Engines…ATK via Jegs…let me know if you have any experience with a remanufactured engine, or a shop in the Southeast I could send it to.
  15. Black92GS
    Intermittent A/C!
  16. crazyd
    Intermittent A/C!
  17. I don't recall the space being restricted, but might have to get a breaker bar on there and a BFH (Big F-ing Hammer).
  18. DIY coilovers. There's no other readily available way.
  19. Black92GS
    Intermittent A/C!
  20. crazyd
    Intermittent A/C!
  21. Black92GS
    Intermittent A/C!
  22. crazyd
    Intermittent A/C!
  23. crazyd
    Intermittent A/C!
  24. Black92GS
    Intermittent A/C!
  25. crazyd
    Intermittent A/C!
  26. Earlier
  27. for shits and giggles i want sparks to fly when it drives it was a $500 car with 160k miles on it lmao i have no need for it besides body parts. i have no need to own a second one but i chose to because that’s what freedom is all about brother
  28. Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
  29. well i can always stretch the tires a little to tuck it more the wheels can’t be wider than the body or it’s going to look terrible
  30. already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes
