  2. Today
  3. Picked up a 1994 Pontiac Grand Prix coupe a few months back for a good price. Im in the process of putting a new motor in it due to an oil pump failure. But I've been thinking about suspension and steering system modifications. There isn't anything available for the 1994 but there's a ton of support for 1997+. Due to differences with the control arms I figured that easiest way to retrofit would be to swap a subframe from a newer Grand Prix into my '94 but I'm not sure if that's possible. From looking up photos online The general shape and mounting position seems to be the same. I was just wondering if anyone's ever done this swap before to update the suspension and steering because I'm sure anything's better than the cartridge strip design in terms of performance.
  4. GnatGoSplat
    Sunroof help again.
  5. GnatGoSplat
    OIL LEAK - 1994 Cutlass LQ1
  6. Yesterday
  7. GnatGoSplat
    Should I go back to stock?
  8. Last week
  9. rcLord510
    TGPForums.com Future
  10. LukeZ34
  11. bluecalais79
  12. The booster is held on with a 1/4 turn lock. Make sure the locking tab isn’t holding it from rotating, (push/pull it into unlocked position.) then get a prybar on the master cylinder studs and rotate it off. It’s so simple it’s stupid. Just an odd ball design.
  13. My father owns a 94 cutlass supreme convertible and its brake booster has failed. Everywhere i look for steps to replace the booster mentions 4 bolts holding the booster from inside the firewall, however, when I go to look, no bolts are to be found. When I look at the new booster, it seems to lock into place using grooves and some kind of locking bar. Nothing I do really does anything to get this booster to move and I am stumped on how to progress. The coter pin is out and the pedal disconnected. The master cylinder and abs contraption is off and out of the way. Theoretically, it should pop right out, yet it holds firm. Any help would be greatly appreciated! Thank you in advance.
  14. Hey everyone, im currently looking for a couple of trim pieces for my 2002 buick regal. Im looking at getting the passenger door trim molding (exterior) and the rear deck seat belt cover (pic attached) willing to buy a whole door if need be
  15. GnatGoSplat
    Rust free rotors?
  16. 94 olds vert
    Rust free rotors?
  17. rich_e777
    Rust free rotors?
  18. Earlier
  19. Jscott
    Sunroof help again.
  20. Black92GS
  21. bluecalais79
  22. cutlassman
  23. bluecalais79
  24. GnatGoSplat
    Rust free rotors?
  25. GnatGoSplat
    Wiring Differences 88-90?
  26. Dude.... I own this car now.... Mine is exactly how your describing yours... From florida originally but Ohio car, hail damage, salvage title, center line wheels and the black hood and spoiler... Bro I have your car lol.
  27. Last American Indian
    Best handling factory w body?
  28. SuperBuick
  29. bluecalais79
  30. jiggity76
    How to clean my Cutlass.
