  1. Yesterday
  2. I have Rev9 coilovers on my 2001 GT. I have 0 pre-load, which helps, but they're still a little bouncy and harsh no matter what I set the damper setting to. I have ZZP coilovers on the red car and, while not perfect, they are much better. I'm trying to figure out what spring rate they are or if anyone knows what I should swap them out for? I'm also going to grab more collars so I can lock them together. They keep coming loose. They have a thin lock washer, but one of them broke.
  3. White93z34
  4. Chapstick
  5. Last week
  6. I think I watched a guy on YouTube do one, and he used a claw hammer.
  7. Getting a pry bar on the studs is next to impossible, given the space you're working with. The service manual for the car calls for a specialty tool literally no one sells. You have to make it yourself. Hope you know how to weld. And grooves to lock it in place? Bolts not work for the engineer? Did narrow wrenches and short sockets not exist in the 90's? The idiocracy of the design choices in the W-Body is astounding! Honda out there making cheap, easy to work on commuters in the 90's while GM was living in their own little city of dreams. Hollow, dim-headed loonies, the lot of them were.
  8. 94 olds vert
  9. Psych0matt
  10. pwmin
  11. White93z34
  12. Earlier
  13. The threads on the fitting for my EGR tube at the exhaust manifold no longer exist. The tube isn't available anywhere. Figured at this point I'd just delete the EGR. Are there any ways to trick the car into thinking there's still an EGR so I don't have annoying check engine light? 1994 Pontiac Grand Prix 3100
  14. Black92GS
    1st Gen W body 14" wheels?
  15. 55trucker
  16. Black92GS
  17. White93z34
  18. 55trucker
  19. Mach 5
    TGPForums.com Future
  20. I talked to the original owner Kevin a year after buying the car and he showed me old photos of it in Florida before it came up to ohio, guy definitely loved this car. Shame it's poptart crust now.
  21. Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
  22. carkhz316
  23. GnatGoSplat
  24. GnatGoSplat
    LED 3rd brake light write up
  25. GnatGoSplat
  26. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  27. cutlassman
  28. Raffaelli
