Toohfu joined the community - Last week
AFM_Hater69 joined the community -
Getting a pry bar on the studs is next to impossible, given the space you're working with. The service manual for the car calls for a specialty tool literally no one sells. You have to make it yourself. Hope you know how to weld. And grooves to lock it in place? Bolts not work for the engineer? Did narrow wrenches and short sockets not exist in the 90's? The idiocracy of the design choices in the W-Body is astounding! Honda out there making cheap, easy to work on commuters in the 90's while GM was living in their own little city of dreams. Hollow, dim-headed loonies, the lot of them were. - Earlier
55trucker started following 1st Gen W body 14" wheels? and Coilover Spring Rates -
Mrob75 joined the community -
GnatGoSplat started following 1997 to 1994 Grand Prix subframe and suspension conversion
