"Flush mount" dash kits for a '96 Grand Prix?
Stock radio swap
Front Tweeters in 1993 Lumina Z34
Should I go back to stock?
FINALLY! Finished HU install in my 89 Cutlass (many pics)
Rust free rotors?
Mo. joined the community -
Best handling factory w body?
If we’re talking bone stock out of the factory, it might be a very close call between the w-body2 (the MS2000 platform(“97”-“03”) GTP Grand Prix & the 1990 Cutlass international. If we’re talking modest mods, it’s going to be the GP (“97”-“03”) & if it’s a full out build, then there is no competition. It’s the GP (“97”-“03”)! Why? I have driven all of them extensively in testing & owned quite a few as well. So; I’m not being prejudiced or a smart guy! It’s just you can’t argue with physics! Now there are minor things that can be done to help improve the inherent physics incorporated into a platform/model & some more than others, but they tend to be somewhat limiting. While you might think all models in a platform have the same physics, they do not! Height, width, wheelbase, weight distribution, etc. are all different & consequencally so goes the base physics that limits the overall performance. Furthermore Super Buick is correct! The skidpad test is just one data point & while it measures lateral g acceleration, it is not a true test of an active suspension & how the suspension components work with regards to the handling. What it is, is the test of three things! The adhesion of the tire coefficient to the pavement, the stability of the components to hold their positions relative to geometrical physics that were designed into the vehicle, I.E. CG & RC, etc. Plus the moment of inertia! But the moment of inertia that is measured in the skidpad is minuscule in comparison to performance handling! Which is a critical element in car handling! What the skidpad test can’t test is suspension rollover, hard instant response handling like slalom racing, accelerometer force generated by such aggressive movements & platform resonance frequency, in which the latter can drastically influence the total performance of suspension performance. - Earlier
