  2. 94 olds vert
    TRW Keyless Entry module
  3. Today
  4. architect
  5. gr_elvis
    93 Cutlass Supreme convertible top issue
  6. GnatGoSplat
  7. jiggity76
  8. GnatGoSplat
  9. jiggity76
  10. architect
  11. Yesterday
  12. It's actually a very easy install. I did it on my '91 Cutlass Supreme coupe on my lunch hour from work. If you're going with an aftermarket head unit, be sure to spring the extra few dollars for the wiring harness adapter, which allows a plug-and-play connection between the new radio and the car, without cutting any wires. You can easily do the installation in under an hour. When I was married, it made a fun afternoon project with my then-stepdaughter to replace the dead radio in her mom's Jeep Grand Cherokee. I taught her how to use a soldering iron as part of the process, and she had a great sense of accomplishment when we turned it on and put in her favorite CD to test it out.
  13. I had to replace the pistons on my '95 vert last fall. They guy at the trim shop said he only replaced them in pairs because when one went, the other wasn't far behind, and it was far more cost effective in terms of labor to do them at the same time. The pistons cost $350 each, which accounted for about half of the total bill. I love that car, but it is an expensive habit, for as little as I drive it.
  14. Human
  15. Please elaborate.....neither the bottom spring seat nor the upper spring seat are fastened to the knuckle, the lower seat, the spring, the upper seat are held in position by the force of the compressed spring against the upper & lower seats. The retaining nut at the top of the shock piston working against the rubber mount keeps everything together.
  16. I have that tool it wasn’t included in the kit I got off Walmart. So I had to buy it off eBay. I had to send the kit back when I wasn’t able to remove the cartridge. The seat is fastened to the top of the knuckle so I couldn’t fit the spanner nut tool down into the tower to remove the cartridge nut. There wasn’t even access to fit that tool you circled to keep the strut elevated from moving. I need to correct a video showing everyone what I am having trouble with. So I can get this done asap. I would love to work on this myself. No one knows how to work on these cars around me. So I’ve been doing all the repairs myself and learning from people in these forums and on fb.
  17. Last week
  18. Black92GS
    Sitting 1995 Regal GS
  19. architect
  20. Black92GS
  21. architect
  22. architect
  23. It’s been just a little over a year now since I got the Regal…so what better way to celebrate that than with some more recent pictures. Nothing much visually has changed except for the refinished wheels and new tires…which was a fairly large, yet subtle change on its own. My intent is to keep the car as stock as possible, and to keep it up to snuff mechanically to be used as a reliable, fair weather cruiser. And to shake things up…. This is the final picture I ever took of my 89 GS before it was parked for good in summer of 2008.
  24. 55trucker
  25. ColesM92GTP
    245/50R16
  26. Actually its been holding up great. I've got over 20k miles on the swap now over 2 years. Nothing major, a couple ripped cv boots which may be because they were junkyard sourced. I highly recommend adding a HTOB spacer. ZZP sells them for around $50. Sits behind the HTOB and moves it closer to the clutch by 1/4" for earlier engagement and longer life. Aside from engineering the trans mount, the hardest part is getting the clutch pedal mounted and situated. The pedal arm needs to be cut & welded into proper position as well. As far as the mount, the low-profile mount I fabbed up works great. Only modification I made was adding rubber bushings under the nuts at the bottom to further insulate the mount from the frame. On an aluminum subframe, it might have to be done a bit different. Might be able to drill two holes and bolt it in the same way, but I haven't been hands-on with an 04+ subframe so I can't say for sure. I'm not a fan of the modified 4T65E bracket method that requires tubular control arms as the mount sits outside the frame. An extra $650 that could be spent elsewhere. There really are half a dozen ways you could fab up a mount but I can say for sure the one I made does the job. 3/16 steel plate holds up well so far. I have also just finished taking the time to document the changes to the tune that are highly recommended for a manual swap: Idle speeds in-gear changed to match P/N as its going to be wired to be in D at all times now. ( I actually added a toggle switch to change between forcing it in D or P, since P is needed for a crank relearn procedure if you need it) DTC codes changed And finally zeroing out all the auto trans stuff:
  27. Psych0matt
    97cutty
    hi
  28. Welcome (back)! somehow I never got out for long, but the last few years I haven't posted as much, been trying to check in more often
  29. Psych0matt
    New member from WI
