92Lumi reacted to a post in a topic: A high mileage LQ1 thread
92Lumi reacted to a post in a topic: 3.4 DOHC to L26 Swap - OBDI to OBD II
GnatGoSplat reacted to a post in a topic: 91 Grand Prix window motors
92Lumi started following 90-94 Lumina Cluster Pinouts and 3.1 to 3.4 or 3.8 swap
Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
